Old 03-31-2019, 09:22 AM   #1
tb13
tb13's Avatar
tb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to behold
Need suggestions, repairing S13 firewall/trans tunnel
I picked up an S13 from a friend of mine this weekend that was heavily modified to run an RB with custom mounts behind the front crossmember. This required a significant amount of the firewall to be cut out along with the trans tunnel to be hacked up. I have no interest in attempting to run a setup similar to that was intended, I am just looking to put a firewall/ trans tunnel back in the car.
How would you guys go about replacing what is missing? Chop an entire firewall/trans tunnel out of a donor car or just replace what is missing? Really want to get the car back in one piece and make something of it, let me know what you guys think!
tb13 is offline   Reply With Quote
Old 03-31-2019, 09:56 AM   #2
afishysilvia
afishysilvia's Avatar
Trader Rating: (31)
afishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfection
Feedback Score: 31 reviews
Drill spot welds out of donor car and swap in entire section would be correct way.
Dont be a pussy...Leave your name
afishysilvia is offline   Reply With Quote
Old 03-31-2019, 10:47 AM   #3
tb13
tb13's Avatar
That will work for the firewall and was the way I was leaning, but wanted to ask.
As far as the trans tunnel is concerned, that is part of the floor board which I can't replace due to the car having a cage. Cutting the same section from the donor car, slightly larger, then trimming to match the missing section should be the best method, right? Will tacking it back into place be sufficient or should it be fully welded into place?
Old 03-31-2019, 11:57 AM   #4
afishysilvia
Trader Rating: (31)
Factory was spot welded and then body seamed. I was planning to just weld mine in completely then using sealer. I think that would be sufficient.
Old 04-01-2019, 09:36 AM   #5
jedi03
my uncle does that with his race cars and bolts in a piece of aluminum...he advises its significant weight reduction...but up to you!
Old 04-01-2019, 03:49 PM   #6
Kingtal0n
Kingtal0n's Avatar
Um wow. I would use it the way it was intended- Put an RB in that sucker and run it.
What can any other engine do that would sound better? Or be any better?
Even if you got an extra 100 or 300 horses from some huge turbo V8 engine it still won't sound and handle better. It isn't worth the extra power at that level in that chassis.
If you were doing a daily driver, a NEO RB25 is affordable and would do 500-600rwhp iirc on a daily pump+meth setting
otherwise a forged RB @ 800-1kbhp E85 is the way to go with something like that in racing
