Old 08-12-2010, 12:48 PM   #1
niteridaz503
niteridaz503's Avatar
niteridaz503 is an unknown quantity at this point
s14 Can you identify this.
Hey Zilvian's just to clarify Ive searched & posted on a few other threads but no definitive answer. Flame suit's near by just in case lol
Well I need help finding out & fixing a few issue's with my recently purchased 5spd 97 240sx. Mainly what i want to know is if the car used to be AUTOMATIC & why my AIRBAG light stays on and my reverse lights don't work at all. The problem is that the airbag light is on, it doesn't blink either another member told me to try & reset the light but after about 15 tries its not working. Also checked plugs & everything seems in order. I also have a check engine light that throws codes:
32-EGR system (currently being looked into)
77-Rear o2 sensor (waiting for pay day to swap out)
103-Park / Neutral position switch <(shouldn't this only be for automatics?)
Now i have 2 pics to help out as well as ECU info, i wana find out so i can fix the issue & get the proper wire harness & ECU (will doing this also maybe turn off my airbag light maybe somehow). Any and all input would be helpful i just wana have the car in proper working order & not cause damage if any down the road
ECU shows: A18 B92 G00 432 5
In this pic i wana know weather or not im pointing to the park neutral plug?
Also can anyone identify this & what its for?
Originally Posted by yetijeff View Post
Hes higher than giraffe pussy lolz
niteridaz503 is offline   Reply With Quote
Old 08-12-2010, 12:50 PM   #2
g6civcx
g6civcx's Avatar
You can help us a lot by giving the following info:
a) What engine is currently in the car?
b) What transmission is currently in the car? It looks like a 5-speed but not sure what kind.
c) What ECU is currently in the car? Auto or manual ECU? SR or KA or what?
Old 08-12-2010, 12:50 PM   #3
240sxfamily
240sxfamily is an unknown quantity at this point
if you read the 5 speed swap DIY you'd figure out what that stuff is for.
240sxfamily is offline   Reply With Quote
Old 08-12-2010, 12:53 PM   #4
SHIFT_destroy
SHIFT_destroy is making a name for him/her selfSHIFT_destroy is making a name for him/her self
Send a message via AIM to SHIFT_destroy
looks like you car was an auto at one time ... that plug goes to the shitfter assembley and i think that other "thing" went to the manual disengauge thing when there was no key in ...... hope that helps a bit ps that plug shouldnt affect anything ... you prolly have a looped nss in you engine bay by the fuse box search 5spd swaps for pics
SHIFT_destroy is offline   Reply With Quote
Old 08-12-2010, 12:58 PM   #5
niteridaz503
Sorry my fault
Cars got a 5 spd KA24DE & im assuming the ECU is also from a 5 spd. Previous owner doesnt know anything bout the car so im hoping to find answers here
Ill have to look that up then, thankz
Great thankz for the info I kinda figured that's what it was for but im too much of a damn perfectionist that i wana do it right lol
Old 08-12-2010, 02:23 PM   #6
niteridaz503
Just to clarify a bit I googled the ECU #:
A18 B92 G00 - turns out its a 95 5spd ECU & the one i need is:
A18 F43 G16 - which is a 97 5spd ECU
Found these number on Jim Wolfs website heres a link if anyone else needs to research their ECU to see if its the right one for their car or just need clarification:
http://www.jimwolftechnology.com/wolfpdf/ECU-ID.PDF
Also by doing this do you guys think it'll have any effect on possibly turning off my airbag light or should i just get that looked into at a dealership/shop?
Old 08-13-2010, 08:39 PM   #7
s13powa
s13powa is an unknown quantity at this point
If you have that whip, then it was definitely an automatic. You might want to take it out. It was attached to the shifter assembly and goes to the ignition cylinder and it locks the key so you cant take it out, or something like that. Very easy to take out.
If your reverse lights dont work. It's because who ever began the swap never finished it.
Another clue is to look under your hood. Passenger side fender. Look to see if you have these 4 plugs. Those by the fuse box. Those are the automatic transmission plugs coming from it.
good site: S14 5-speed Transmission Swap - Electrical Connections
Another thing. Can you start it in gear? I'm asking to see if you have a clutch pedal switch. Prevents the car from starting with the clutch engaged. I left mine out.
Hopefully I was right. If not, oh well.
s13powa is offline   Reply With Quote
Old 08-15-2010, 04:00 PM   #8
niteridaz503
ill look into that website but yeah figured out it was originally automatic so i wana change out the whole wireharness so i can get it all running right. Also what do you mean exactly bout the previous person not doing the swap right? is there something i can look into to fix the reverse lights & so forth?
Old 08-15-2010, 04:09 PM   #9
LayNLow
LayNLow is making a name for him/her selfLayNLow is making a name for him/her self
He means whoever did the 5spd swap didnt do it right because your reverse lights dont work. Look at the DIY 5 speed swap and youll see everything you need to know.
LayNLow is offline   Reply With Quote
Old 08-15-2010, 04:38 PM   #10
niteridaz503
oh i see now ok cool im reading it right now too
airbag, codes, ecu, s14
