04-04-2015, 09:14 AM | #1 |
Work VS-XX 18x9.5 +41 F, 18x10.5 +13 R, 5x114.3
Location: Suffolk, Virginia Means of contact: PM Price: $2,000 ***FRONT TIRES ARE NOT INCLUDED*** Wheel Brand/Model: Work VS-XX Diameter: 18" Lug Pattern: 5x114.3 Width: 9.5" front, 10.5" rear Offset:Fronts are +41 rear offset is +13mm (previous owner installed larger lips. Rear wheels were originally 8.5" wide and +38mm offset) Tire size: 285/35ZR-18 (*** TIRES ON 10.5" REAR WHEELS ONLY***) Tire brand: Hankook Tire model: Ventus R-S3 XL Tread life left: 100% Wheels were disassembled, and the faces were painted Kia Carmel Yellow, and larger lips put on by previous owner. I recently bought these and had the faces taken back off and the lips polished professionally by professional rim repair in Chesapeake to shine them up. Pro rim also fixed a nick in the paint on one of the faces, verified that the seals are good and mounted and balanced the tires. Neither the wheels or tires have been driven on since I had them refinished/mounted. I'll also include a small jar of the Kia yellow touch up paint that I got when they fixed the nick. The reason I'm selling is because these require fender flares to fit the rear of my 300Z. They fit the front well but require a 1" spacer to clear the SRT-8 brembo big brake kit that I'm putting on. I like the wheels but I changed my mind about flaring the rear and I'd like to get something that will clear the brake kit in the front with either a smaller spacer or none at all. So here's what they do fit: Previous owner told me that he had these on a Lexus SC-400 with normal sized tires, and then on an S2000 with stretched tires and -8 degrees of camber. They were on an Acura NSX when I bought them, with stretched tires. Also, they fit the front of my 90-96 300ZX with stock brakes and stick out 20 to 30 mm to far in the rear without flares. Please do your research before inquiring. Make sure you know that they will fit. If somebody wants just the rear tires, make me an offer and I will have them pulled. I don't want to sell the wheels alone unless I have already sold the tires. Local pickup only please. These are way too expensive for me to feel comfortable shipping. Pictures: Last edited by Yardjass; 01-31-2019 at 06:06 PM.. |
04-09-2015, 06:22 AM | #2 |
Bump. So the fronts fit on the rear of my car perfectly, and the rears have more brake clearance. Someone get these before I re-lip the rears back to 8.5's and put these on my car.
06-16-2015, 12:38 AM | #7 |
Miata engine refurb is gonna be ramping up in a couple weeks. When that's all finished, I think I'm moving forward with the re-barrel of these because I wouldn't mind seeing them on the Z again. If they sell first though, they sell
01-24-2016, 06:24 AM | #15 |
Just ordered the last of the parts for my engine swap. That is starting soon and when that finishes, these are getting re-lipped and put back on the car if I still have them. Still available for now though.
