Old 01-23-2010, 10:09 PM   #1
redhatchy92
redhatchy92's Avatar
redhatchy92 is an unknown quantity at this point
window stoped working
i know it has probably been covered a billion times but i cant find any direct answers. i window stopped working out of the blue. what would cause this? motor of amp.??? i need to know asap because the window is down and its supposed to snow.
to be faster you have to slow down
WTB OEM SILVIA AERO SKIRTS!!!!!! PM ME
redhatchy92 is offline   Reply With Quote
Old 01-24-2010, 10:30 AM   #2
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
check yo fuses
My shoe is undesired
undesiredshoe is offline   Reply With Quote
Old 01-24-2010, 10:47 AM   #3
redhatchy92
That would be a good idea. Lol I'm checking it after work
Old 04-11-2019, 10:54 AM   #4
vgbu
vgbu is on the path to ruinvgbu is on the path to ruin
you ever get the window problem found, my friends 93 240sx the windows work seldom, only when cold
vgbu is offline   Reply With Quote
Old 04-11-2019, 11:45 AM   #5
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
so..... you need to do some testing when the failure occurs, to determine what the actual cause is.
-is the switch not outputting signal to the motor?
-is the motor getting signal but not operating?
-is the switch getting power but not outputting a signal to the motor?
Old 04-11-2019, 03:30 PM   #6
Coupes_FTW
Coupes_FTW's Avatar
Coupes_FTW is making a name for him/her selfCoupes_FTW is making a name for him/her self
askjeeves.com
Coupes_FTW is offline   Reply With Quote
Old 04-11-2019, 04:11 PM   #7
brndck
brndck's Avatar
Originally Posted by Coupes_FTW View Post
askjeeves.com
http://lmgtfy.com/?q=askjeeves.com
Old 04-11-2019, 06:46 PM   #8
vgbu
power windows not working.
Ok did a quick check there is power to the fuse under the hood, the fuse ohms out ok, at the drivers door removed the switch with test light I get NO power to any of the wires on the switch connector, went to library got a print of wire diagram looks like there is an ignition relay could this be the problem. Any ideas, google shows the amp but this one appeared good no cracks in the solder.
This is a 93 convertible, are rear windows powered through the main switch also as they don't work either.
Old 04-12-2019, 03:26 PM   #9
vgbu
Ok got a wire diagram, I checked power at fuse under hood it is good, ohmed the fuse it is good, turned ignition switch on still no power at the wires drivers door, wire diagram shows an ignition relay, found the (brown) relay behind the fuse box inside the cabin, pulled and taped on the relay now when I turned on the key I could feel the relay activating, checked for power at the door wire (W/B) I have power, connected switch and windows work.
Old 04-14-2019, 12:17 AM   #10
SteffbuiltNOLA
SteffbuiltNOLA is an unknown quantity at this point
Sounds like a sticking relay. Replace it.
SteffbuiltNOLA is offline   Reply With Quote
Old 04-14-2019, 04:52 PM   #11
brndck
brndck's Avatar
Ok got a wire diagram, I checked power at fuse connected switch and windows work.
Hooray! You did some actual work and fixed it!
Pat yourself on the back and have a milkshake!
Old 04-16-2019, 10:08 AM   #12
SteffbuiltNOLA
Now you need to send him a cookie
Old 04-16-2019, 10:09 AM   #13
brndck
brndck's Avatar
NO COOKIES FOR HIM ONLY COOKIES FOR ME
