04-10-2019, 07:29 AM | #1 |
Engine dies when going from third or fourth or fifth to neutral
hi guys. my engine is dying if i am in either third fourth or fifth and go to neutral. also it dies if i go above a certain a rpm. any advice? im running a ka24de with various mods, including a 248 248 cam swap.
04-10-2019, 11:52 PM | #5 |
well then how do you expect people to diagnose an issue based on fuel? How do you know how much fuel is going into the engine and whether or not its burning properly?
If you want a guess its probably maf placement related. The maf requires non turbulent positioning, with straight pipe on both ends, and it needs to be placed far enough from the turbo and throttle body to avoid the small perturbations caused by the compressor wheel and water hammer effects of a shutting valve. Other than that it could be a slew of issues, from air leaks to bad Oxygen sensor but without a wideband to backup data its just guesses. Need much more info or suggest trying standard procedures, compression test, pressure tests (crankcase and intake pathways) timing test |
04-11-2019, 08:27 AM | #6 |
Trader Rating: (130)
Feedback Score: 130 reviews
+1 for we need more information.
-was it running good before? -did you CHANGE something, and then this started happening? -when you say "various mods" we have no idea what that means. intake and exhaust? 300 shot of nos? roots style blower? cmon dude you've gotta provide useful information for us to be able to help you |
04-11-2019, 12:38 PM | #7 | |
Intake K&N with stock MAF Battery moved to drivers side 4-2-1 headers Full exhaust system with 2.5 outlet Coilovers Emusa Custom seats with Tamata Belts ebay Short shifter Dual Exhaust Cam Swap 248 248 Ventilated Disks Diff LSD 300zx Strut bars (rear & front) Gas Regulator Electronic Fan Z32 Fuel Filter These are all the mods. I don't have a Wideband because the previous owner never got to putting it, and I am on the process of doing it. Then again, Im a broke college student lol. |
04-11-2019, 12:51 PM | #8 | |
start by checking for vacuum leaks |
04-11-2019, 01:51 PM | #9 |
04-11-2019, 02:01 PM | #10 |
what are you using for cam gears? iirc the 248/248 cam gear swap needs an adjustable cam gear to get the new cam into correct position.
04-12-2019, 10:27 AM | #11 |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
I see a short ram intake, how far away is the MAF sensor from the throttle body?
