Old 12-26-2019, 12:08 AM   #1
95se
95se's Avatar
95se is an unknown quantity at this point
Electrical clicking sound with engine cutting out
I tried to upload a file of the noise but not able to. For a while i've had this clicking sound behind the dash that occurs with the engine cutting out. Started about a yr and half ago but only happened ever so often. Lately it's gotten much worse where I'm afraid it's going to die but hasn't. Used to it never really did it on the highway but w it's doing it at any speed. CEl came on before this started happening with codes knock sensor and egr. When this started happening no new codes came up but when I started it one time the air bag light started flashing. This same clicking (glitching noise) also occurs when I start it but it starts fine. Then a few weeks ago the CEl went off came back on then went off again. Any ideas. It's stock ka manuel.
z32 front brakes, spl tc rods
95se is offline   Reply With Quote
Old 12-26-2019, 12:31 PM   #2
coupesallday!
coupesallday!'s Avatar
Trader Rating: (18)
coupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the rough
Feedback Score: 18 reviews
Send a message via MSN to coupesallday!
Check all the fuses and relays, I had a problem one time where my s14 would make a clicking noise and wouldn’t start, it turned out to be the 75A fuse for the alternator
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 12-30-2019, 12:51 PM   #3
jedi03
if you have clicking noise could be wire grounding out...
Old 01-04-2020, 11:22 AM   #4
95se
95se's Avatar
Took it in and they saId the fuel pump relay was doing the clicking noise but it still did it when they swapped it out. They checked other things and are going to swap the ecu and see.
Old 01-04-2020, 11:26 AM   #5
95se
95se's Avatar
They found the fuel pump relay to be clicking but swapping it out couldn't fix it. So they are going to swap in another ecu and see if it stops it.
Old 01-04-2020, 11:31 AM   #6
S14rebuild
Sounds like a bad ground
Old 01-04-2020, 12:06 PM   #7
95se
95se's Avatar
Maybe, swapping the ecu didn't stop it.
Old 01-04-2020, 03:06 PM   #8
S14rebuild
Pull up the fuel pump wiring diagram on the fsm...see where it grounds...probly loose or corrosion
Old 01-04-2020, 03:44 PM   #9
95se
95se's Avatar
I'm sure they'll check everything. This shop specializes in 240''s and knows them as well as anyone.
