Old 12-15-2020, 03:05 AM   #1
Changi558
Changi558 is an unknown quantity at this point
Help!! RB Speed Sensor Part Numbers
Hey Guys,
I have a 1991 1Via with an RB25det engine swap. It's paired to an RB25de gearbox.
I'm trying to get the correct speed sensor to fit it and get my speedometer working.
I've got an RB25DET speed sensor which fits into the gearbox hole but doesn't mesh with the Speedo drive because I believe the DET sensor is longer than the DE version and has 20 teeth instead of 21.
I'm lead to believe that the RB25DE speed sensor is actually common / shared between both the RB20DE and DET gearboxes. I have an RB30DE speed sensor and I know that doesn't fit the 25DE gearbox.
What I'm after is if anyone knows the exact part numbers of the below:
RB20DET speed sensor
RB20DE speed sensor
RB25DE speed sensor
Or if anyone knows anything different to the above info with pics.
Cheers Al
Changi558 is offline   Reply With Quote
Old 12-15-2020, 08:54 AM   #2
JrDarknes
JrDarknes's Avatar
JrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud of
Originally Posted by Changi558 View Post
Hey Guys,
RB20DE speed sensor
RB25DE speed sensor
Cheers Al
Your car is a S13, The rb speed sensors will not work with the S13 cluster if I remember correctly. Use the non turbo USDM 300zx sensor for the rb25.
Instagram: Nismo_Lk
JrDarknes is offline   Reply With Quote
Old 12-15-2020, 12:30 PM   #3
Changi558
Your correct. I encountered that problem at the start and have since had a conversion done so all the RB sensors to work on my cluster. I can power/turn the sensor by hand or drill and it will put the signal through to the cluster fine now. It's just a matter of getting the right sensor to physically mesh with the gearbox internals.
Old 12-15-2020, 04:00 PM   #4
NukeKS14
NukeKS14's Avatar
NukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really nice
Right. The NA Z32 speed sensor is going to fit because the Rb25 and VG30 trans are the same internally.
https://www.z1motorsports.com/speedo...gaAvCXEALw_wcB
Part # 25911-30P10
https://www.z1motorsports.com/speedo...8aAnnTEALw_wcB
Gear part # 32743-30P20
Looks like you'll need a C clip as well
NukeKS14 is offline   Reply With Quote
