Old 10-22-2019, 09:06 PM   #1
Sr20-Vert
Sr20-Vert's Avatar
Sr20-Vert is a well-known jackass
sr20det haltech launch control help
i have a question i have a s14 with a sr20det ps1000 and cd009 transmission i have no speedo because of cd009 and no clutch switch because it was an auto before the swap is there anyway to get the launch control to activate so i can send it !! thanks
Sr20-Vert is offline   Reply With Quote
Old 10-23-2019, 07:21 PM   #2
S14rebuild
Why not wire in ur own clutch switch? The pedal bracket has the threaded holes already welded to it, add switch and ur own wires...done
Old 10-24-2019, 11:52 AM   #3
TheRealSy90
TheRealSy90's Avatar
Just install a generic switch where the factory clutch switch normally goes.
Or if you install the switch so that it's only triggered when the clutch pedal is all the way released, you could let the clutch slip out and launch while on the 2-step before the 2-step disengages. Could help with keeping that initial traction in the launch.
Such a good signature.
