Old 01-03-2018, 08:50 PM   #541
BOROSUN
BOROSUN's Avatar
BOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfection
if you guys are following this news. i think its was 30-40% performance lost from bios or windows patch. yikes.
https://www.cnbc.com/2018/01/03/amd-...its-chips.html
i cant find any benches for the newest driver.
i guess its time to bring back the fury x.
http://www.youtube.com/watch?v=dj3k7q4fe9Y
BOROSUN is offline   Reply With Quote
Old 01-06-2018, 01:03 PM   #542
BOROSUN
BOROSUN's Avatar
https://www.pcgamesn.com/amd/amd-veg...specifications
12nm ryzen and vega right around the corner and 450b & x470 mobos as well. AMD should take advantage of the intel bug fiasco and launch it on feb.
& More annoucement ON THE WAY!!!
http://www.pcgamer.com/what-to-expect-from-ces-2018/
i finished the itx build on thrusday. had to downsize my nzxt 140rad/fan aio to a corsair h60 120mm rad/fan. ran memory profile @3200 (i'll adjust timing later) but, no OC on cpu yet.
Old 01-06-2018, 11:07 PM   #543
BOROSUN
BOROSUN's Avatar
intel coming with kabe lake loptops with rx vega. yet still no vega gpu available.
https://en.wikichip.org/wiki/intel/cores/kaby_lake_g
Old 01-07-2018, 04:09 AM   #544
BOROSUN
BOROSUN's Avatar
https://videocardz.com/newz/exclusiv...ds-from-asrock
DAMN...
ASRock Fatal1ty X470 Gaming K4
ASRock Fatal1ty X470 Professional Gaming
wtf-->ASRock Fatal1ty X470 Gaming-ITX/ac
im soo late in the game.
Old 01-07-2018, 02:02 PM   #545
Future240
Future Moderator
Future240's Avatar
Random but any of you have an z97 atx mobo you dont need? I am stalking one so i can finally oc my 4690k.
Originally Posted by ThatGuy
Old 01-07-2018, 03:24 PM   #546
BOROSUN
BOROSUN's Avatar
my son is using it for now, 4790k & asus gryphon w/ armor kit.
i might switch over to TR2 if they release 12nm couple of months and ill hand down this zen itx to him.
Old 01-07-2018, 06:06 PM   #547
BOROSUN
BOROSUN's Avatar
3dmark benching
https://www.3dmark.com/fs/14640752
fs1.1 score:17150. 4ghz @ 1.37v
https://www.3dmark.com/spy/3096797
ts1.0 score:7756 4ghz @1.37
i can definetly OC higher but my cpu cooler sucks. 97c after the timespy bench. maybe ill change the thermal grease and low voltage some more.
i did a prime95 blend test . holy jesus the comp shut down cause the temp was sky rocketing . it didn't crash, though.
Old 01-08-2018, 01:56 AM   #548
BOROSUN
BOROSUN's Avatar
http://www.youtube.com/watch?v=rOTKgvPUXN8
KINDA still expensive for a bare bone.
wonder if you can build cheaper with amd apu
https://www.forbes.com/sites/antonyl.../#7229d23511ed
Old 01-09-2018, 10:05 PM   #549
BOROSUN
BOROSUN's Avatar
itx done
the noctua fans are ugly.
Old 01-10-2018, 04:22 PM   #550
Future240
Future Moderator
Future240's Avatar
97c?! Hot damn that is warm.
I am stalking /r/hardwareswap and ebay for a z97 so I can get this 4690K to 4.5ghz.
That is a great itx build. I often where why out of all the color combos why noctua sticks with the ugly brown colors.
Old 01-13-2018, 03:38 AM   #551
BOROSUN
BOROSUN's Avatar
this is why..... corsair h60 amd mounting really sucks.
cleaned it all up and dropped kryonaut grizzly paste.
change tighter timings to cas 14 @ 3200
4ghz @ 1.3v
53c avg 65c max while playing squad. ran prime95 , it never hit 70c.
phanteks evolv shift has terrible air flow.
Old 01-14-2018, 03:35 PM   #552
BOROSUN
BOROSUN's Avatar
lol. well its about time.
http://www.pcgamer.com/noctua-unveil...r-accessories/
this my up coming plans...
alphacool eisbaer. pump/block only
i have a spare 120mm monsta rad. i'll see if i can fit it.
http://www.youtube.com/watch?v=wnYirzEx0mM
delta ffb 120mm 150cfm
forgot noctua has the nf 3000 182cfm 120mm fan
Old 01-15-2018, 01:14 AM   #553
BOROSUN
BOROSUN's Avatar
some more time spy bench.
3200mhz tighter timing. its showing wierd slower core speed.
https://www.3dmark.com/spy/3141757
cpu score :8265
vs stock settings 3.7ghz boost 4.1ghz 2100mhz
https://www.3dmark.com/spy/3141508
cpu score: 7790
vs 4ghz 3466mhz
https://www.3dmark.com/spy/3141584
cpu score: 8725
i couldn't boot 3600mhz my actual ram speeds. 3466 has problems booting. so im stuck @ 3200mhz. i haven't tried 3333mhz yet.
i need to get cinebench
EDIT:
im booting now 3600mhz ram specs.
cinebench score 1728
EDIT:
updated asrock itx bios 4.40
booting on asrock profile [email protected] 3600mhz
cinebench score 1768.
i tried running amd csm p-state overclock. but, finding the values for the memory timing was confusing. i ended with super loose timings 22T. result was 1725 on cinebench. also P-state OC wont boot with asrock profile.
Old 01-16-2018, 09:36 PM   #554
BOROSUN
BOROSUN's Avatar
http://www.youtube.com/watch?v=uT-pP4wvLV8
Old 01-17-2018, 08:11 AM   #555
Future240
Future Moderator
Future240's Avatar
woot! Scored a prestine z97 mobo from ebay. Asrock Pro. Now just stalking some ram.
Old 01-17-2018, 11:31 PM   #556
BOROSUN
BOROSUN's Avatar
gratz
speaking of ram
https://www.techpowerup.com/240725/s...t-gddr6-memory
Old 01-18-2018, 06:41 PM   #557
Future240
Future Moderator
Future240's Avatar
I saw that article today. Maybe Volta might drop this year.
Old 01-19-2018, 11:29 PM   #558
BOROSUN
BOROSUN's Avatar
i hope so. competition has lacked so much, nvidia can just hang back and keep milking pascal.
Old 01-21-2018, 05:49 AM   #559
BOROSUN
BOROSUN's Avatar
http://www.youtube.com/watch?v=eW4OingkXnE
lol trolling jay
Old 01-22-2018, 06:28 PM   #560
BOROSUN
BOROSUN's Avatar
wtf my 1800x hit 4.5ghz
Old 01-24-2018, 06:05 PM   #561
Future240
Future Moderator
Future240's Avatar
Is it stable though?
Old 01-24-2018, 07:14 PM   #562
BOROSUN
BOROSUN's Avatar
i ran cinebench after seeing that spike and it crashed. so , no.
it only happens it when im playing squad and i was playing squad for 2hours before that.
it was stable [email protected] 3333mhz with soc offset 70+mV. ran thru everything. i dunno whats going on with squad. but, im back at 3200mhz with 14/14/14/34 soc on auto just to be safe.
Old 01-24-2018, 07:14 PM   #563
KAT-PWR
KAT-PWR's Avatar
Just put together an i7-7700K system through black friday.
Asrock extreme4
I7-7700k
asus 1060 6gb
G.Skill 3000 cl15 16gb
Custom water loop
Seasonic 750w modular
240gb samsung ssd
500gb samsung ssd
Corsair spec alpha case
Stable on 5ghz but waiting for delid kit cause the temps get hot on stress test
Got back into PC's earlier last year and got my feet wet overclocking this system i put together for cheap
Asus p5qc
Custom water loop
Corsair vengeance ram
q9650 i want to say i was only able to get it stable at like 3.9ghz
GIANT thermaltake MK1 case
Helped my roomate build a pc
NZXT case
i7-8700
Aurous mobo
G.skill flare 3200 16gb
Thermal take 360 AIO cooler
1080 TI seahawk
2x 500gb samsung ssd
1x crucial 240gb
MRP Manufacturing
Old 01-24-2018, 07:26 PM   #564
BOROSUN
BOROSUN's Avatar
dope rig. but, clean up that wiring.
which coolant is that?
my aquacool & hard pipes dreams got crush when i found out its too tall for my itx case.
Old 01-24-2018, 07:51 PM   #565
tootall4la
tootall4la's Avatar
tootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to all
Silicon lottery
tootall4la is offline   Reply With Quote
Old 01-24-2018, 08:26 PM   #566
KAT-PWR
KAT-PWR's Avatar
Yeah the drives are in a bad spot, haven't played with it too much. Plan to make some changes to the loop and change drive positions. Have a few ideas brewing.
The coolant is XSPC concentrate I mixed. Its pretty nice.
Its all budget oriented. I had a generic aluminum rad that i swapped for a copper, only got me 2* better cooling. Ebay water pump and res. Amazon raystrom rep waterblock.
MRP Manufacturing
Old 01-25-2018, 07:59 PM   #567
BOROSUN
BOROSUN's Avatar
http://www.youtube.com/watch?v=DJOVdmd7NHQ
try this on your 7700k
Old 01-25-2018, 10:06 PM   #568
BOROSUN
BOROSUN's Avatar
lol jim toast pcper
http://www.youtube.com/watch?v=Uw0ZzA9wTFE
Old 01-26-2018, 11:53 AM   #569
KAT-PWR
KAT-PWR's Avatar
Meh I'm just going to delid and Conductonaught it.
MRP Manufacturing
Old 01-26-2018, 04:13 PM   #570
KAT-PWR
KAT-PWR's Avatar
Pic with some UV action. Pic is hard to get obviously. Tubing is white, fluid/res is UV laser green by XSPC
MRP Manufacturing
