Old 09-17-2013, 05:53 PM   #91
CaptainVlad
CaptainVlad's Avatar
CaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really nice
Why not stay with Z32 in the rear, aren't they VERY similar to the size of the STI calipers? I say that because there is a relatively long thread on this site somewhere documenting putting those exact calipers on the s chassis. From what I remember the guy doing the swap had issues with adapting the sti calipers to the rear. IIRC, some of the stuff wasn't working together very well.
CaptainVlad is online now   Reply With Quote
Old 09-17-2013, 06:22 PM   #92
IceMochaBowl
Trader Rating: (-1)
IceMochaBowl is an unknown quantity at this point
Feedback Score: -1 reviews
i have q45 calipers and rotors up front on my s14 and stock in the back. and i dig em.. definitely added braking power. but its not over the top.. +1 for q45 fronts..
IceMochaBowl is offline   Reply With Quote
Old 09-18-2013, 06:25 AM   #93
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
That's what I ran for the longest time, Q45 fronts with Hawk HPS pads, Z31 caliper bracket in the rear with 2003 Altima rotors and Hawk pads really balances out that set up.
onehundredoctane is offline   Reply With Quote
Old 02-11-2015, 02:03 PM   #94
SaUcEy
SaUcEy's Avatar
SaUcEy is an unknown quantity at this point
The hate on Wilwood in here is hilariously ignorant.
Continue.
SaUcEy is offline   Reply With Quote
Old 02-12-2015, 01:49 PM   #95
Cash
Cash's Avatar
Cash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond repute
Send a message via AIM to Cash
R33 GTR Brembo front calipers mount directly without the need of a bracket. Used the S13 to Z32 ss conversion lines. I had to cut away the dust shield for the rotor to fit, of course. I'm still using the stock BMC and rear brakes, but plan to upgrade to Z32.
Looked bad when I got them, so I had them powder coated.
Super easy install
Cash is offline   Reply With Quote
Old 02-12-2015, 03:18 PM   #96
jaxshawn
jaxshawn is an unknown quantity at this point
What lines are people using for 4 piston ctssv front brembos
jaxshawn is offline   Reply With Quote
Old 02-12-2015, 04:06 PM   #97
crzsteveo
crzsteveo is an unknown quantity at this point
^I think I saw somewhere that the z32 lines would work? im currently going through the process of doing that swap with mazworx brackets
crzsteveo is offline   Reply With Quote
Old 02-12-2015, 05:18 PM   #98
jaxshawn
That's good to hear, I already have z33 track rotors I'm just trying to get in contact with teg guy from ctsvbrakeswap.com for his brackets now
Old 02-12-2015, 05:36 PM   #99
Agamemnon
Agamemnon's Avatar
Use the stock banjo style 240sx lines.
Old 02-12-2015, 08:01 PM   #100
jaxshawn
Thanks any idea if ctssv calipers with z33 track rotors will clear 17" wheels
Old 02-13-2015, 10:35 AM   #101
Future240
Future Moderator
Future240's Avatar
*pics*
Looks good. I didn't know r33 brembos were a direct fit. Might be a cheaper alternative than Evo/Sti. I wonder how those stop compared to Z32 and Evo 9 brembos.
Originally Posted by ThatGuy
Old 02-13-2015, 08:41 PM   #102
crzsteveo
i highly doubt it.
are you using the brackets for the 6 piston calipers 2009+ CTS-v, or the 2004-2007 CTS-V 4 piston calipers?
the 6 piston will not clear 17s.
that's why I am going with the 4 piston caliper setup. cheaper price then a pair of z32 calipers. also larger pad/rotor surface area and overall a great price tag for a brake upgrade.
Old 02-13-2015, 09:11 PM   #103
jaxshawn
There are a lot of gM guys using 17" wheels and clearing 13" rotors with a little grinding.
I've got all my parts ordered just gotta pick up pads I'll post up if my wheels fit
Old 02-15-2015, 12:05 PM   #104
Cash
Cash's Avatar
Yeah, I didn't realize either until I got these, but it makes sense if you think about it. I got the front rotors, calipers, and Nismo pads from a guy here in Atlanta for around $650 if I remember correctly. Unfortunately I can't find rear R33 Brembos for sale anywhere, which is why I'll probably just use Z32 rears.
I had Z32 front brakes on my old S14, but I can't really compare the two because I never pushed either of them to the limits. The Z32 brakes have PLENTY of stopping power for these cars. I just got the Brembos because they look cooler.
Old 02-15-2015, 03:43 PM   #105
chiboy002
chiboy002 is an unknown quantity at this point
i was always under the impression that r33/34 brembos, and i think r32 brembos, required drilling out the thread on the knuckles
However, a long time ago, I found a japanese company that made adapters, as you can see the brembo's have a sleeve on the ears (where the bolts go through) that you push out and replace with smaller diameter so you can use stock bolts. They were cheap, however I since lost the site.
street dancer.
GLEAM
Old 02-15-2015, 04:03 PM   #106
Agamemnon
Agamemnon's Avatar
Only the R34 require that the knuckle be drilled out to 14mm. R33/32 are bolt on.
Old 02-24-2015, 11:26 AM   #107
driftslideways
driftslideways is an unknown quantity at this point
J30s all day
driftslideways is offline   Reply With Quote
Old 02-24-2015, 12:25 PM   #108
onehundredoctane
Continue.
Even tho that was years ago, yes, it is ignorant.
To compare, my previous Q45 set up to the current Wilwood set up, isn't not even fair. Oddly, the Q45 set up would lock up the fronts and it was almost unpredictable, now with the Wilwoods I have yet to lock the fronts up no matter how hard I apply the brakes. The front brakes are so much more predictable now, pad wear is very even, where as with the Q45 set up the pads wore unevenly which I guess could be blamed on the calipers?
Old 03-20-2015, 10:38 PM   #109
jaxshawn
Just FYI finished my CTS v brake swap
Gen 1 CTS-v 4 piston brembos
Stock style brake lines, z32 conversion lines will work to
Z33 track rotors 12.75"
Ctsvbrakeswap.com brakets
And they clear my 17" FNs
Old 03-22-2015, 06:17 AM   #110
1slowlance
1slowlance is an unknown quantity at this point
I've got q45 fronts and kept the stock rears on my s13. Pedal is kinda mushy, so I'm guessing my bmc took a dump on me. Been trying to decide on swapping it with a stock one or I've read some people do z31 turbo bmcs for that swap. But yeah, other than that they work great and I like em. Big upgrade over just stock fronts.
1slowlance is offline   Reply With Quote
Old 03-22-2015, 09:20 AM   #111
Y0SH
Y0SH is a jewel in the roughY0SH is a jewel in the roughY0SH is a jewel in the roughY0SH is a jewel in the roughY0SH is a jewel in the roughY0SH is a jewel in the roughY0SH is a jewel in the rough
Originally Posted by Bushido View Post
I did the altima rear rotors with z31 carrier and stock rear calipers, i didn't do it to improve braking, just did it cause stock rotors look tiny inside 18's...
i had a z31 carrier on a parts car lying around and i needed new rotors anyways... it probably ain't worth it to go out of the way to do it.
...moral of the story, save up for mustang rotors and dual z32 calipers.
what year of mustang rotors work, and is it the front or the rear? My dad just bought a 05-08 GT and it has slotted rotors and I'm pretty sure he's only pulling the drivetrain.
Y0SH is offline   Reply With Quote
Old 03-30-2015, 11:31 AM   #112
nujabe
nujabe's Avatar
nujabe can only hope to improve
i run the wilwood kit and i love them..
Untitled by Aallmighty, on Flickr
Some black guy who lurks zilvia.
nujabe is offline   Reply With Quote
Old 04-02-2015, 08:44 PM   #113
jaxshawn
Anyone have info on 1st gen ctsv rear caliper swap
Old 04-03-2015, 10:19 PM   #114
crzsteveo
^where are you getting this idea from? haven't heard of it....
im waiting for mazworks to get their brackets back in stock for the fronts...
Old 04-03-2015, 11:06 PM   #115
jaxshawn
i went with ctsvbrakeswap.com brackets an z33 track rotors
looking up rear brembos in my free time working at a parts store noticed the 05-ish CTSV rear brembos are also 4 pistons just smaller, and were a decent price. figured id post up see if anyone did it before
also a full cts V brake set up would win the internet right?
Old 04-05-2015, 08:17 PM   #116
crzsteveo
^it would indeed win the internet. maybe a dual caliper bracket with the Vs instead of z32
Old 04-06-2015, 09:53 PM   #117
NISSeAN
NISSeAN is an unknown quantity at this point
I too have the Q45/Altima/Z31 setup. It's closer to stock brake bias which distributes braking force more evenly than say Z32 up front AND for the weight of the S13 (can only say for what I own) it's perfect IMO.
NISSeAN is offline   Reply With Quote
Old 04-06-2015, 10:43 PM   #118
matts13vert
matts13vert's Avatar
Trader Rating: (31)
matts13vert is an unknown quantity at this point
Feedback Score: 31 reviews
Let me know what you guys think, I sell chromoly front brackets and I am currently working on a modular rear bracket that can run dual Z32 on a Z32 rotor or CTSV 4 piston with a Z32 caliper on a Z34 rotor for a hydraulic ebrake.
Here they are on my build!
matts13vert is offline   Reply With Quote
Old 04-07-2015, 08:05 PM   #119
crzsteveo
^I wanted to order brackets from you, but I want to run the 4 piston 07 CTS-V caliper up front with 17s.
So what V brakes are you using in the rear? 04-07 front V brakes? 04-07 rear V brakes? or the gen two newer V rear brakes? straight bolt on?
Old 06-30-2015, 11:19 PM   #120
grimm199
grimm199's Avatar
grimm199 is an unknown quantity at this point
For you Q45 guys out there that are running Hawk HPS pads, where do you order them from?? When I messaged Hawk for the part number, they sent me this;
"I regret to inform you that we do not make the front pad for your vehicle.
I have access to over 15,000 different applications and fitments. Infinity is the only company to use that pad shape and they used it only on the Q45 for 3 years"
grimm199 is offline   Reply With Quote
