05-18-2015, 05:32 PM | #1 |
1996 240sx, kouki front, sr20det $7,000
Hello, I am selling my 240sx, which is located in NYC. It has a clean title.
I am not interested in any trades. I can take you, as a passenger, for a test drive. If you want be the test driver, then you hold the title, and i hold the cash. mileage is 123,xxx the car pulls strong, and shifts well color is a GM blue about 200 miles driven since the swap & new parts kouki front end (metal hood & fenders) s13 sr20det (rocker arm stoppers, bled hla, new front & rear main seals, new thermostat & waterpump, new intake & exahust & iacv gaskets, new valve cover gaskets & spark plug grommets, greddy pulleys, unorthodox pulley, s14 oil strainer, new turbo gaskets) megan turbo manifold stainless steel turbo lines walbro fuel pump HKS front mount intercooler Greddy air intake Z32 MAF Apexi PowerFC with FC Commander wiring specialties upper & lower harness s14 speed sensor koyo radiator Z32 master cylinder Z32 front calipers cross drilled front & rear rotors stainless steel front & rear brake lines new front & rear transmission seals new clutch fork pivot ball ACT flywheel, 600225 Streetlite ACT clutch, 6 pad Xtreme race disc 6240006 & N015X Xtreme pressure plate vlsd Magnaflow high-flow stainless steel catalytic converter HKS Hi-Power exhaust KYB shocks TEIN springs bads: the grille between the headlights is just a piece of painted metal mesh the shocks should be replaced the clearcoat is peeling on the hood, roof, and trunk there are paint chips in the front bumper one of the fans makes noise the rear tires are garbage (I can include better 225 tires for free) no A/C I stripped the driveshaft carrier bearing to chassis hole, and repaired it with a helicoil the transmission makes a whining noise when decel in gear Last edited by happybik3r; 05-20-2015 at 11:11 AM.. Reason: added more pictures |
