01-08-2012, 01:45 PM | #1 |
KA24E-T No spark..... PLEASE SOMEBODY HELPPPP
Ok here's my current situation.... I have a 2year build. KA24E-T (sohc) in my 240sx. I AM NOT GETTING ANY SPARK!!!!
What I have changed /checked already. NEW MDS BLASTER COIL 2 wired up correctly... With orignal stock coil grounding tab. The ignition control module is not grounded however due to coil not being stock, and coil relocation. (from what i have heard the ICM doesnt need grounded anyways). I am getting power at the top positive and neg terminals of my blaster coil. But i have a feeling no power is coming out of the blaster coil.... This is my 2nd coil because thought maybe i had a defective one.. still the same.... My distributor was removed and checked.... looked good... but never know what could be inside. so i am having a friend come over tomorrow so we can swap it and check it.... ECU is a JWT tuned ecu and is brand new The ignition control module is also new. I took the 4 prog ignition resistor out of the harness and replaced it with a oem one from nissan still no spark.... I have 40psi of fuel but no spark does anyone have any idea's I have tried everything also goes without saying checked all my grounds etc.. fuses etc... THANKS ZILVIANS |
01-14-2012, 04:45 PM | #4 |
as in the last thread I posted toI have the manual for this motor I would take a distributor cap off inside there look for to gold screws remove the gold screws and he would a tears to be a copper plate there you will see a very thin metal wheel mounted on the side of that metal wheel is a sensor known as an optical sensor I would check thatthen the distributor rotor itself if you have spark at the coil pack and no spark at the wires that it's in the distributor
01-14-2012, 04:46 PM | #5 |
you can email me at [email protected]
01-31-2012, 02:02 PM | #7 |
He's been banned. He was obviously a tool with what he said on his second post and he was trying to rip people off in the marketplace.
1990 Nissan 240SX w/KA24DE - New project 1984 Mazda RX-7 GSL-SE 13B |
01-31-2012, 03:19 PM | #8 |
Apologetically
Have you checked the polarity of the ground, most cars are ground(-). Thats ground negative, or ground(+). Again ground positive, make sure the battery matches. replace the rotor inside the distributor cap, check the optical sensor.
