09-03-2016, 04:01 PM | #1 |
88 Supra 1JZ R154 11.5K
Location : NYC Contact: PM/Text(PM For Phone Number) Price - 11,500 OBO Email- PM ME Here is my 1988 Supra with a 1JZ/R154. I am the third owner of the car and everything has been done on the car expect paint work. Car does have faded clear so no surprises here. Body has about 140,xxx but the engine and trans have a little over 500 miles. Car is on wastegate spring at 12 psi. The car has a lot of new bits replaced and I have no leaks or anything of that sort. I am selling my last supra to get into a family sized sedan. Low ballers are not welcomed. No joys rides. I decided not to part it and try to sell it as a complete car as of now. Engine JZA70 1JZ-GTE Rebuilt All Toyota Gaskets ARP Headstuds ARP Main Studs ARP Rod Bolts Clevite Bearings HKS 264 Cams With Port/Polish HKS Cam Gears New Toyota Valve Seals New Toyota Valve Cover Gaskets New Coolant Hoses Everywhere Polished Intake Manifold Polished Valve Covers NEW OEM Toyota Coil Packs NEW Toyota Water Pump NEW Toyota Oil Pump TT Rear Sump 370 Stock Injectors New Cam/Crank Sensors Functional PS/AC/Heat Turbo DM 67mm Turbo Kit Straight Out Downpipe SS Feed Line/Hardline Drain 2.5 Intercooler Piping 4" Intercooler QSV Braided Boost Lines DM Turbo Blanket MK3 Carbon Fiber Cooling Plate Transmission Rebuilt MC R154 Bearings/Synchros/Seals Genuine C's Shifter ACT Six Puck Kit New Master/Slave New OEM Mount New PP Bolts New Speedo-Cables New Input Shaft Seal New Output Shaft Seal Redline MT-90 For Trans/Diff Electrical Mines 1JZ ECU Boost Cut Removed HKS EVC 1 Boost Controller JZA70 harness with new plugs Autometer Elite Boost Autometer Elite Oil Pressure Autometer Elite Engine Temp AEM Wideband Battery Relocation With Breaker Fuel System Braided -6/-8 Teflon Lines Bosch 044 In-Tank(All Hardlines) Areomotive Fuel Filter Areomotive FPR Interior Sparco Seats Stock Blue Interior, Clean 8/10 New Shiftboot Rewrapped Armrest Kenwood Deck Alpine 200W Amp 6.5 Pods Suspension Volks 17" with Federal Radials Tien Coilovers New Brakes/Rotors New Master Cylinder New Braided Teflon Brake Lines New Toyota Rear Spherical Bushing New MOOG Tie Rods/Ball Joints Energy Suspension Bushings |
09-05-2016, 06:46 PM | #3 |
damn minus some body blemishes this seems pretty clean.
Any videos of it? (Just curious to see how she runs)
I change cars too often... Ho.Mo.Co. |
