10-21-2014, 11:05 AM | #1 |
S13 KA Coupe, and your mom.
Open to any reasonable offers, OBO
No trades I also just found out my school screwed me on my loans(thanks fasa) so now the funds from this will go to school -_- Now it just sits in my garage chilling till it's next drive. I usually turn it on every other day and take it around the block so it can run through it's systems. I also have the car fax on the car. Here are the facts: Cons Side Dents(driver rear quarter panel, and driver rocker panel) If you want more pixs I can send them through. Needs paint Power Steering Line (Leaking about $100 bucks for) Dash crackified Needs Smog (I have no one to go to! still looking) What it has: Typical blah blah blah CLEAN TITLE. Godspeed Coils >1000 Miles Head Rebuilt and broken in (Replaced all gaskets head up and oil Pan) >3000 Miles CX Racing Turbo and intercooler kit >300 Miles 370cc SR20DET injectors ECU Tune Z32 MAF AEM Filter Stage 2 clutch Exedy New Slave Cylinder Brembo Rotors stock size (Drilled and slotted) EBC Brake Pads (All Four, Red Stuff) All New sensors (Coolent Temp, Oxygen sensor, Idle Air, knock sensor, coolant temp, oil pressure etc.) Turbo NGK Spark plugs, Bosch Wires, New Dist cap and Ignition rotor New Transmission oil (Royal Purple) New Engine Oil (Mobile 1 10W-30) New Stock Lower control arms, Tie rods inner and outer both sides. Power by Maxx spacers for tie rods (Better steering angle) HKS Cat-Back exhaust Speakers, radio, and a little sub with amp Rear camber arms (Godspeed) Welded Differential Replace radiator (Stock), thermostat (Mishimoto lower temp), and water pump (Stock) New fuel filter (Basically any maintenance needs have been done) I have some decent seats and black carpet Comes with extra rims, (the ones in the trunk all 4), VLSD that has been re-shimmed that I have on the side. I have all the paper work ready to go whenever you are. If you have any questions go ahead and PM or text me. 909-241-zero five six five Cash only since now I have to pay for school. |
240sx, clean title, coupe, s13, turbo |
