05-28-2019, 04:19 AM | #1 |
clutch leaking
The clutch is leaking and idk what the part is call but i got a picture were its leaking from and also air is getting into the system.
https://imgur.com/a/hoz71Ww |
05-28-2019, 07:43 AM | #2 |
Trader Rating: (22)
Feedback Score: 22 reviews
That’s the clutch master cylinder. Replace it, and while you’re at it, you may as well replace the slave cylinder and eliminate the damper in the clutch hardline (that’s if a prior owner hasn’t already done so).
05-28-2019, 11:41 PM | #4 |
Clutch Master:
https://frsport.com/exedy-mc153-oem-...x-se-1989-1998 Clutch Slave: https://frsport.com/exedy-sc560-11-1...x-se-1989-1990 These are the same two parts that I run on my '93 hatch. I also run a S/S line that deletes the unnecessary damper box/hardlines. Frsport is down right now. I can post a link once they bring it back online. |
