03-05-2019, 07:27 PM | #1 |
FS: 1996 Nissan 240sx with 819wHP VH45DE-T
I am sad to say that I am letting go of my 1996 Nissan 240sx. This car has been lots of fun. After finding the stock-internal limit of my VH45DE to be 819wHP, and watching the rotating assembly put 2 holes through the engine block, I have not had the time to swap another engine back in. The car basically went straight from the dyno room back into my garage, where it has sat for 8 years now. :frown:
The engine's internals were ALL stock, so swapping in another used stock engine should be all it takes. Anyway, here's the high-level specs: Engine: Infiniti Q45 V8 (4.5L, DOHC, ALL STOCK) Transmission: 300zx twin turbo 5-speed Clutch: SPEC stage 5 sintered iron disc Transmission Adapter: Water-jet cut adapter plate, milled bell housing Engine & Trans Mounts: Custom, solid steel mounts Turbo: Garrett 72mm from a Detroit Diesel engine, 60mm wastegate with external dump Intercooler: 24” x 12” x 3” fed by 3” mandrel-bent tubing Fuel: E85 or 93 octane Engine Management: AEM EMS, Low-Impedance Injector Driver Board Fuel Injectors: 150 lb/hr low-impedance Fuel Pumps: 3 parallel in-tank Walbro 255HP's staged at boost levels Fuel System: -10AN Feed to Aeromotive fuel pressure regulator Cooling system: Radiator relocated to trunk to make space for turbo Driveshaft: Custom Intake Manifold: Custom, CAD CFD-Designed, short-runner, balanced plenums Exhaust Manifolds: Stock tubular manifolds re-designed to point forward Exhaust: 4” Diameter w/ resonator & muffler Rear End: Stock, welded spider gears Interior: 10 point 1-3/4” roll cage Included Extras: Many extra Nissan parts in my garage! I have a lot! Power: 819 wHP / 727 wTQ @ 20psi boost (stock rods broke) 759 wHP / 685 wTQ @ 18psi boost Pictures/Info: https://drive.google.com/open?id=16_...oySHgl-askfJe4 Keep in mind the car has been sitting for 8 years in my garage. It is dusty and dirty. This car is the opposite of a "show car", but I have never been one for body work. Last dyno pulls: https://www.youtube.com/watch?v=u-UqJUbkNi0 https://www.youtube.com/watch?v=EWbqrM5VTrY https://www.youtube.com/watch?v=G86ThQ8yJ2M Jeff |
03-05-2019, 10:10 PM | #2 |
Price..........
Www.PowerAutosports.com |
03-07-2019, 02:58 PM | #5 |
so, if im reading this correctly. the car still has the broken rods in it (and possibly two holes in the block)? therefore the car is no longer making 819 hp.
it makes 0 hp. |
03-07-2019, 07:58 PM | #6 |
That's right. So, how can I get you into this car today? How about I top off the fuel tank for you or shine the flat tires it sits on?
Sent from my SM-G930VL using Tapatalk
[email protected] |
03-09-2019, 02:26 PM | #7 |
Now asking $3000 OBO
[email protected] |
03-18-2019, 06:10 PM | #10 |
Now $2,000 OBO. Here's some pictures of the condition it's in.
https://drive.google.com/open?id=1-C...MfENIGwHrZ2tYm Price includes any other Nissan parts I have in my garage (MAF's, injectors, ECUs, engine heads, alternators, PS pumps, AC compressors, starters, etc). The garage needs to be cleaned out!
[email protected] |
