11-12-2019, 08:04 AM | #1 |
S13 180SX RHD Master Cylinder Upgrade?
I am wanting to do the Evo 8/9 front brake caliper/rotor upgrade and it appears that most people recommend that I need to upgrade the master cylinder also. I see most people recommend the Z32 1-1/16 BMC. The problem is that all of the master cylinders that I find are all for left hand drive cars. I have a RHD 180sx car so the brake lines are on the opposite side. Any recommendations on which BMC to buy and where to buy it?
11-12-2019, 12:36 PM | #3 |
I did the z32 brake swap all around and used a 1" bore, for a 95 Nissan pathfinder. 1" bore to go with my manual brake booster. Can't say if they will line up with Factory hard lines, as I am using a chase bays oem relocation kit.. They come in different bore diameter with the ports on the correct side you need it on. Mine is a doorman part #m39976 with the factory nissan looking reservoir.
i paid less than 75$ for a NEW one, not re-manned. check out this site for BMC size comparison... https://importnut.net/300zxbrakeswap.htm#MC Last edited by Super_OK_S13; 11-12-2019 at 02:52 PM.. Reason: bmc part number/year |
