Originally Posted by pacotaco345
How did you touch this up with the paint being base-clear? The leading edges of my fenders and the end of my hood is starting to get a bit worn..
I applied the base with an arts brush. I repeated coats until it covered well. I waited a little then brushed on the clear. I laid it on semi heavy. You don't want to acually brush the clear on, rather kind of spread it over the area. If you touch the underlying base with the brush it will remove the paint. I pretty much just used the brush to dispurse it. Let it cure for a couple days, wet sand to blend and buff.
