01-03-2020, 08:43 PM | #1 |
What did I miss?
I have a 95 s14, KA, manual and as far as so know it came stock that way. I got it as a roller with the engine harness in the trunk so it's been an adventure figuring out where everything goes. I believe I have everything hooked up correctly but when turning the key on it doesn't crank, no click from starter. The fuel pump doesn't prime or turn on and the wipers don't work ( included because part of the same harness). I tested the fuel pump it works but isn't getting power. I am getting 12v at the relay but no trigger signal for the relay. I tried unplugging the ignition plug and jumping the wires but that didn't work either so I don't think it's the switch.
Is there an immobilizer or something built into these cars that would prevent both from working, or is there something I've missed? It has a security light, but does that just have to do with an alarm? A previous owner also seems to have put a toggle switch in line for the neutral switch on the clutch pedal. Is this evidence of an auto to manual swap or ghetto anti theft? ( Looking into these write-ups as well) I am still trying to figure this out and looking through the FSM and past posts. Just trying to cast a wide net to solve the problem and get a more experienced perspective. Thanks for any help and advice. |
01-03-2020, 09:19 PM | #2 | |
01-03-2020, 10:15 PM | #3 |
I have power at the switch, the white wire in slot one. I have 12v and cont through the switch in the correct positions. The only thing in question there is the B/R wire. when the multimeter produces sound for cont. On all wires it makes a continuous sound. But the B/R only makes a short chirp is there anything wrong with that?
01-04-2020, 10:15 AM | #4 | |
The Game you lose haha |
01-04-2020, 11:42 AM | #5 | |
(I have no idea what colors do what or go where, I'm giving general procedural advice, you will have to check against the FSM to see what does what) |
01-04-2020, 11:09 PM | #6 |
I apologize I am still not that great at troubleshooting electronics. I get it now, I was testing it incorrectly. The ignition switch is good.
I tested every relay, hooked them up to a battery then tested cont. all clicked and tested good. I also verified that they weren't stuck open or closed. I have been trying to find out how to remove the immobilizer, but people only want to share the process through PM. If anyone knows how to do it and is willing to pm me how to I would appreciate it. Thank you |
01-05-2020, 01:39 AM | #7 |
I don't think there's anything stock to that effect, if there's something it's one of those terrible little aftermarket boxes that fry, you've just got to find it, it's always different, according to the whims of the installer.
Could be wrong. The s13 is an on/off dumb key type of car. |
01-05-2020, 08:05 AM | #8 | |
I just looked at the FSM and it says the anti theft will only shut down the starter motor so I was a bit wrong in my previous statement
The Game you lose haha Last edited by kyral; 01-05-2020 at 08:48 AM.. |
01-05-2020, 10:58 AM | #9 |
That's what I have been seeing as well, that the anti-theft only disables the starter. I am probably going to bypass the security system for the starter and run the wire from the ignition directly to the starter and see what happens. I am running out of ideas for what to check.
01-05-2020, 01:07 PM | #10 | |
Take that shit off, use crimps to fix the wires as necessary (no twisting the wire as you insert it). the starter signal wire passes a good bit of current and goes thru the switch with no relay. Try jumping the starter (with a remote starter or ghetto approximation of one) with the key on, or ideally, with someone holding the switch in start (the injector strategy changes for strong starting, it'll just sort of choke and sputter to life after a moment of cranking, if you start it in "on", but won't hurt anything). |
01-05-2020, 02:30 PM | #11 | |
but looking back and reading OP original statement, looks like this isn't fitting the problem they are experiencing you said you confirmed you are getting 12v at the white wire on the ignition switch?
01-05-2020, 02:40 PM | #12 | |
This guy knows everything...listen to him |
01-05-2020, 03:26 PM | #15 | |
Havent seen u help at all in here, except quote posts and bitch its not the info the op is looking for... |
01-05-2020, 03:38 PM | #17 | |
And I looked at the FSM it looks like its a problem with power to the switch, or the switch itself I see mechanical moon mentioned something and I might have derailed the thread a bit ill own up to that and being wrong
01-05-2020, 04:06 PM | #18 | |
Ur right....never help anyone here. |
01-05-2020, 05:12 PM | #19 |
So I have pulled all the plastics from the column and the majority of the interior and found no aftermarket security systems. I verified I am getting no power to my ECU from neither the ignition switch or the other 12v wires, I don't have my notes in front of me so I don't recall the pin numbers.
Sorry, it takes a while to respond. I don't have service in my barn so I make a plan of what to check and don't come back inside until I need to. Yes, I do have 12v at the switch and the switch tested good when I checked it. FSM references never hurt, could very easily have something I overlooked that ends up being the solution. Thank you, everyone, for the help. |
01-06-2020, 08:15 PM | #22 |
I think I found it! The black/red ECU power wire had gotten pushed back in the connector. I think the acsd connector, the bastard with the lever to lock it in. Went to back probe it and it clicked back in car turns over and fuel pump primes.
I greatly appreciate everyones help on this and I apologize for it having been something so simple that was the issue. |
