Old 04-23-2019, 03:45 PM   #1
wrenchheader
wrenchheader has a little shameless behavior in the past
Loose chassis issue
I have a 91 RHD s13. Completely stock suspension, 18in wheels. My issue is when I hit the right size bump or dip, if feels like my back end jerks over to the right and then feels like it goes right back to feeling planted. Did a visual check at arms and such, but everything seems normal. Happens when driving straight. Everything seems solid if I slalom the car some, just happens on the right size bump or dip. Any thoughts? Its pretty noticeable to the point that my wife asked about it while riding, without me ever mentioning it to her.
wrenchheader is offline   Reply With Quote
Old 04-23-2019, 03:50 PM   #2
anthony_240
anthony_240's Avatar
anthony_240 is an unknown quantity at this point
I can guarantee you will need to replace some of your stock suspension arms, look for damaged / worn bushings, if you have a pry bar jack your car up and start prying at all suspension components, putting stress on the rubber bushings until you find your culprit.
anthony_240 is offline   Reply With Quote
Old 04-23-2019, 03:52 PM   #3
anthony_240
Don’t forget to also check your shocks
Old 04-23-2019, 04:08 PM   #4
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
subframe bushings may be worn as well, and/or steering rack.
Old 04-24-2019, 08:02 AM   #5
tuzzio
tuzzio's Avatar
subframe bushings
This. I had this exact same issue, and once I bought in my solid risers, the issue went away. When I dropped my subframe, one of my bushings literally fell out of the subframe.
Old 04-25-2019, 12:33 PM   #6
wrenchheader
I'll have to check, it would explain why I cant wiggle the rear wheels at all....
Old 04-25-2019, 12:38 PM   #7
wrenchheader
Shocks are definitely needing replacing. Have some new coilovers order. That being said, seems odd that an issue with the shocks would cause a horizontal issue 🤔
Old 07-19-2019, 05:04 PM   #8
TEN_2nd_BUSTER
TEN_2nd_BUSTER's Avatar
TEN_2nd_BUSTER is an unknown quantity at this point
FOLLOWING.... My car has the same issue, but I just got mine on the road so I'm taking on 1 battle at a time.
TEN_2nd_BUSTER is offline   Reply With Quote
Old 07-19-2019, 06:25 PM   #9
wrenchheader
Installed my new coilovers and fixed the issue!
