Old 02-04-2021, 11:39 PM   #1
srh666
srh666's Avatar
srh666 has made poor choicessrh666 has made poor choicessrh666 has made poor choicessrh666 has made poor choicessrh666 has made poor choicessrh666 has made poor choices
Aluminium on steel corrosion
We all hate this problem right?
Any tips on preventing ?
srh666 is offline   Reply With Quote
Old 02-04-2021, 11:50 PM   #2
Silv1401
Silv1401's Avatar
Silv1401 is an unknown quantity at this point
On which surface?
Sent from my SM-N986U1 using Tapatalk
Silv1401 is offline   Reply With Quote
Old 02-05-2021, 08:21 AM   #3
KA24DESOneThree
KA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfection
Anti-seize between the parts. Surface coating (paint or plating/anodizing- the zinc in zinc-plated parts becomes sacrificial and hard-anodized aluminum is not conductive) on both parts. Keep parts as dry as possible.
Car and trailer manufacturers use non-conductive plastic tape. Not possible if we're talking wheel/hub interface, so that's where the anti-seize/surface coating comes in.
If the part is immobile, like an alloy strut brace, you can ground a zinc anode to the aluminum and replace it when necessary. It'll corrode rather than the steel of the body, nuts, or studs and the alloy of the strut brace.
PS- it's called galvanic corrosion and there's a ton about it on the 'net. Lots and lots of solutions out there.
KA24DESOneThree is offline   Reply With Quote
