Old 01-19-2012, 10:16 PM   #1
240trooper
240trooper's Avatar
240trooper is a well-known jackass
Send a message via AIM to 240trooper Send a message via Yahoo to 240trooper
Smog help!!!
So I have failed smog twice due to the fuel evaporative control functional test failing. I've read a couple of threads and found that the test consists of testing the pressure between the gas tank and purge line to the charcoal cannister. I don't know much about the evap system but I wanted to know if the o ring that sits on top of the gas tank between the tank and the top that holds the fuel pump could be the culprit? A few months back my 255 lb pump went out and I replaced it with a brand new stock pump, I'm thinking maybe the o ring didn't sit right and that could be the problem? By the way I drive a stock 91 hatch ka24de. Im going to check it tomorrow but if that isn't the problem does anyone know what it could be? Thank you.
2.7L
240trooper is offline   Reply With Quote
Old 01-20-2012, 12:58 AM   #2
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
it`s worth a try.
rcdad123 is offline   Reply With Quote
Old 01-20-2012, 09:54 AM   #3
Tokona-x
Tokona-x's Avatar
Trader Rating: (140)
Tokona-x is an unknown quantity at this point
Feedback Score: 140 reviews
Send a message via Yahoo to Tokona-x
That O ring could most definitely be a problem I would check there first and if its not that I would then go to a shop and have a smoke test done its the quickest way to find your problem and that way you wont be just shooting at it in the dark heres a vid check it out
Auto Repair Tip Wilmington Delaware - Fuel Tank Vapor Leak 1995 Mitsubishi Galant - YouTube
I have five speed bolts if you need any
Custom 2+2 E brake Cable brackets sold here!!!!!
Tokona-x is offline   Reply With Quote
Old 01-20-2012, 08:48 PM   #4
240trooper
240trooper's Avatar
Thanks. I didn't have time to check the o ring but I will def. get that smoke test done. Thanks.
2.7L
Old 01-20-2012, 09:16 PM   #5
rcdad123
rcdad123's Avatar
yeah, that smoke detector method is the shit. no more guessing.
240sx, evap, hatch, ka24de, smog
