View Single Post
Old 09-15-2020, 06:32 AM   #26
Krazy719
Krazy719 is an unknown quantity at this point
Go ahead & put the motor on tdc then pull off the cap on the distributor check if the rotor is on cylinder one if it isn?t pull the distributor out & reset it & if it is on cylinder one I would still pull it out & reset it it could be off a tooth & not firing right best of luck man also what you can do is put some starter fluid in the intake if she back fires from it it?s definitely your ignition timing if you believe everything else is set on timing correctly
Krazy719 is offline   Reply With Quote
