Originally Posted by gaz_moose
could you bolt the plastic fan to the rear of the viscous coupling? to gain more room at the front, I don't know what the rear clearance on the fan is like.
Its a must to do this. Radiator is a Mishimoto, acording to info on the web its almost the same thickness as a Koyo.
Tubular is a big no. Biggest reason is car has to pass inspection and that is a lot easier with "stock look". Second reason is that I'm not skilled enoght to make it so I would have to pay someone to make all this and that would probably not be cheap.
For a little update I have done some more messurements and prepared to get the engine loose. Will update more as sone as I have more progress.
