I’ve got the factory options sheet somewhere for my s14. I believe the sunroofs were only available on SE models and it was called a “power moonroof”. I also believe that if your sunroof is manual it was a dealer installed item, which in that case you can probably find a trim for if you are lucky. But us factort sunroof boys are still SOL. I actually messaged the seller again recently about the trim and never received a response...
