This is interesting and I am looking forward to some better pic showing the quality. A lot of people are confused as to what this part actually does. It is not designed to form a water tight seal against the roof skin, but only to keep larger debris out like leaves, etc. There is a channel around the sunroof frame, under the glass, with a drain hose connected at each corner that lead and drain into the rockers under the door. If you are experiencing leaks, one of these hoses have come disconnected or are clogged.
