97 S14 w/SR20. Running SR condenser fan with SR clutch Fan. Its all bolted up. Clutch Fan works no issues. I'm wanting to run the Condenser fan now. There are only 2 wires and would like to get it to run when the AC kicks on. Would I need to tap into the High or Low blue Relays? One is power and other ground. If this is the case, which relay would I want to tap into and is it the Blue/pink wire? Thank you.
