Originally Posted by TheRealSy90
I've been considering getting rid of my Xcessive solid aluminum mounts and going to your stuff, only thing is i have to set my engine height specifically since i'm using a rhd turbo manifold on a lhd car and the clearance to the steering shaft is really tight. Are the studs on your mounts long enough to allow me to shim the mounts a bit higher with a washer if I have to?
How much are you looking to shim? A quarter inch?
