If your running SR clutch fan and shroud, you don't need the A/C fan. I wanted to install the A/C fan also in my SR, however the harness that I'm using is by 'Wiring Specialties' does not have the Hi and Lo fan wired in. Yury purposely didn't wire them in due the stock A/C fans failing after time. He did mention, if you're using the SR Cluch fan and Shroud combo it would be more than enough to keep your condenser cool. Anyways, that's upto you.
S14 326 whp, 311 tq @ 15 psi HKS F-CON V-PRO
