Check your distributor timing again, I had the same thing and it was a little too fast. So you gonna have to retard it most likely. Unless you messed up timing which happens...good luck.
I'm actually on the way to the garage to start breaking everything down for a timing chain change. I dreaded this, but needs to get done. :'(
