Originally Posted by domocress
i was wondering how you set up your hydraulic ebrake?did you use a proportioning valve.. is there such thing as a one way check valve? i want to prevent from welding on another caliper. thanks for your help and if possible can i see pics of what you did
My s13 didnt come with the proportioning valve on the madster cyl but it was mounted on the pasnger side of the engine bay so I passed the lines through the fire wall and hooked the lines in front of the valve I didnt run my lines to the master cyl because I didnt want to run my lines next to the exhaust manifold
