Originally Posted by DriftVader
changed out fuel filter with a new one. if it is the fuel pump, how would i go about seeing if that the issue? replace it? i can test the pressure off the FPR.
Sorry- didn't see this...
You can pull the line off the rail feed and verify good fuel flow from the pump by turning the key on & watching the fuel come out... and before you put it back together, put an inline pressure gauge between the filter & rail to check the pressure.
