VQ swap driveline
Many have wanted to know where you get drivelines made and what yoke to use for the new one. Here are the details. The driveline experts say the stock 350z/G35 driveline is non-rebuildable so don't waste your money aquiring one, (like I did.)
Instead find a good local driveline shop and have them make one. Mine turned out perfect. They supplied all parts and balanced it for $240.
Phoenix Rack & Axle (602) 252-8255
The yoke they used:
Spicer part number 7091.
It has 32 splines and is a perfect fit into the 350Z/G35 manual trans. It does use a larger diameter U-joint. You will have to shorten or remove the metal ring on the trans where the yoke slides in.
You can buy this yoke from them or your local driveline shop. Driveline Specialist inc. sells the yoke for $84. I'm sure either of the companies listed can make the entire driveshaft and ship it to you if you don't have a good local driveshaft maker. They will need an exact measurement from the trans output shaft to the diff input shaft faceplate and the spacing on the faceplate holes so they know which flange to use on your driveshaft. Happy hunting guys.
Driveshaft Specialist Inc.
8327 McCullough Avenue
San Antonio TX 78216
210.342.6622 Phone
210.342.7074 Fax
1.866.455.6622 Toll Free
Orders and Free Tech Advice
