Originally Posted by zooopreme
I take it that this is for your daily and occasional track. So with that said, I would go with the 225. The stretch is less extreme & you'll still have some meat. Don't know if you feel comfortable with taking this size to the track but it shouldn't be too bad.
Meh. I want the 225, but I'm just thinking if I go a tad bit more on the hardcore side with a 215 i'll be able to sleep way better at night. Plus, tires are the only thing I don't get a baller discount on, so I want to "measure twice and cut once" per say
Originally Posted by fliprayzin240sx
If you decide to go 9j, +25 is about as high as offset you can go to clear most coilovers. If you go 10j, it gets iffy there since you have even less tolerance to clear the suspension, the wheel-well and the fenders, specially on the smaller amount of space under an S13. Personal recommendation would be about 9j +20 or +15 ish for S13 fronts.
Star Specs!!! Those are the only tires I run for my fronts. Just not sure if you're willing to spend that much loot on tires.
I'm running these new Generals for my rear and so far they're pretty good for All-Season tires. They're called G-Max AS03, its they're replacement for the UHPs and traction has been consistent and predictable.
Only issue you'll have is finding the correct size.
Star Specs Sizings from TireRack:
215/45ZR17 87W $143.00 (ea.)
225/45ZR17 90W $145.00 (ea.)
235/40ZR17 90W $160.00 (ea.)
235/45ZR17 93W $149.00 (ea.)
245/40ZR17 91W $175.00 (ea.)
General G-Max:
215/45ZR17 91W $99.00 (ea.)
215/50ZR17 95W $115.00 (ea.)
215/55ZR17 94W $111.00 (ea.)
225/45ZR17 91W $109.00 (ea.)
225/50ZR17 94W $113.00 (ea.)
225/55ZR17 97W $118.00 (ea.)
235/45ZR17 94W $117.00 (ea.)
235/50ZR17 96W $113.00 (ea.)
235/55ZR17 99W $119.00 (ea.)
245/40ZR17 91W $125.00 (ea.)
Actually, now that I'm looking at Tirerack, I've heard nothing but good things about Hankook RS-3 or the V12s as far as bang for the buck.
Thanks for the advice!
I could run a 235/40 but the clearance will suck. I'm running a 17x9 +12 on the front with a 235/40 right now until I get the car out of paint, which, obviously, is when i'll be putting the other 2 17x9.5 +28 on. The 235/40 on the 9 +12 fits kinda awesome, but i can't lower the front as much as desired, and it rubs sometimes...I FUCKING HATE RUBBING. I'm thinking the 9.5 +28 will stretch the 235 more and I think a 9.5+28 would fit like 7mm more inward...
