Originally Posted by HyperVerbal
huh... you'd think by now someone would have replied "REMOVE your old shims on both side (14&17 of diagram) replace them both with (blank) & (blank) for 2 way or (blank) & (blank) for 1.5.
This is not really possible, because most diffs are setup differently. Depending on wear, setup, original shim sizes (to account for the difference in original gear sets), crush sleeve settings, etc..
You just have to open yours up, measure and adjust accordingly, if it's still not where you want it, redo it with a bigger shim...
This is nothing new here folks, it's just Diff 101
