Originally Posted by JAYTRON
For Auto to 5spd swap, how big a hole do I need dremel'd for the clutch pedal to the firewall?
IIRC im pretty sure a 1 3/4 inch hole saw will work out. you need a right angle drill, or a small size air drill cause the space you have to work is pretty tight.
