Well about that time I noticed that the tranny crossmember was hanging too low. So i decided to make a new one to clear the exhaust we will be building.
Chop off the old ends and rotate them to the correct angle.
Fabbed up a new bracket.
All tig welded.
Made some slots on the mill.
Made a box plate to eliminate any flex since this thing will have over 1000 whp.
Then made some frame gussets for the tranny mount.
Tig welded them all in.
Then made some upper arms out of 1/2 stainless tubing. Added some roll cage brackets, and mounts for the tranny tunnel.
yup.
Then from inside the car, I cut out the dynamat from the tranny tunnel, and drilled a hole.
Then I tig welded a nut to a washer and put it in place.
Tack welded it in with the tig.
Then put the dynamat back over for a seamless finish.
Well thats it for today.
Hope you enjoyed this. I will try to post up my fun days at work if you guys would like to see.
