It all depends on your price range. Ground Control can set you up with a decent koni/eibach kit, they even offer some custom valved koni's for certain applications.
I would not recommend buying their coil-over conversion kit if you plan on participating in any real type of motor sports. The coil over conversion kits are good if you simply want to have a lower car and slightly stiffer ride. Of course some cars do not respond as well lowering, especially if the hardware doesn't permit usage of the threaded sleeves Ground Control uses.
If you haven't yet, give them a call and see what they can offer you. Tell them what application you will be using the car for and they will come up with a set-up for you.
