| | #1 |
| Zilvia FREAK! ![]() | Advan SA3 (silver/polish) - 17x7.5+38, 17x8+38 - 5x114.3 Advan SA3 Silver face, polish lip - 2piece construction 17x7.5 +38 17x8+38 These wheels were pulled off my sw20 MR2 and then I used them on my S14 for SCCA. Very effective setup for track guys because you can use a 235 width tire all the way around without running aggressive camber. The center hub bore is for Toyotas, which is smaller than Nissans, so you will need at least 10mm spacer to clear the hub. For Z32 brakes you need at least 15mm spacer. There are a couple nicks in the paint on the faces, and the lips could use a good polishing. As typical for 12 year old wheels, the clear coat has some spiderwebbing in some spots but can be polished out. Wheels only - $500 picked up. Shipping available - PM for quote Wheels + tires - $600 picked up. Shipping NOT available Tire only - will be sold after the wheels are sold. Located in Socal (Torrance, CA). PM me or email teknolust72@gmail.com for a faster response. ![]() ![]() Mounted with 10mm spacers ![]() ![]() Tires: Front - Bridgestone Potenza 225/45/17 ![]() Rear - Dunlop 235/45/17 ![]()
__________________ |
| Sponsored Links | |
| Bookmarks |
| Tags |
| advan, jdm, rims, wheels |
| Thread Tools | |
| Display Modes | |
