Old 08-18-2012, 09:34 PM   #1
WTB: Redtop SR ECU
#62 ECU; 100% working order. PM me please.
95 Nissan 240SX S14.5 RHD
TOMEI Powered Redtop SR20DET@17psi(322whp/319tq)
bkuhl is offline   Reply With Quote
Old 08-18-2012, 11:18 PM   #2
brndck's Avatar
Trader Rating: (95)
Feedback Score: 95 reviews
mines "boost up" #62 ecu for redtop sr20det
I am the future Eric Castro
Old 08-19-2012, 12:11 AM   #3
Thanks Ty, I need a stock one so I can get it tuned/chipped by JWT or RS-E.
current one is no longer sending signal to the fuel pump.
GT2871 .64 a/r
810cc DW inj.
Walbro 255 lph pump
JWT 272 in/ex cams
Old 08-19-2012, 08:45 AM   #4
brndck's Avatar
Trader Rating: (95)
GT2871 .64 a/r
810cc DW inj.
Walbro 255 lph pump
JWT 272 in/ex cams
One Thing you should check first, I've seen multiple #62 ecus with this same problem where the ecu no longer triggers the fuel pump relay (ECCS relay). The ecu provides the ground for the relay to close. What I have done in the past, with great success, is to clip the wire and run the side that goes to the relay (not the side from the ecu) to a manual switch that will ground the relay when switched on. This also works great as a kill switch for security.
My last #62 ecu had this problem and that's what I can up with. You can find an ecu pinout on goggle images, the terminal should be labelled "fuel pump relay" or "ECCS relay".
Old 08-19-2012, 08:55 AM   #5
silviaNC's Avatar
I have an e6 on hand. Let me kniw if it is any good to you
silviaNC is online now   Reply With Quote
SEO by vBSEO 3.6.0 PL2
