| Wanted to Buy Post your needs and wants here. |
| | #1 |
| Zilvia Junkie ![]() Join Date: Apr 2010 Location: Lansing, MI Age: 26
Trader Rating: (3) Feedback Score: 3 reviews | no crazy expensive stuff be reasonable and must have pics I need a FMIC and piping , BOV , tuned Ecu , oil lines , gauges WHAT I GOT SO FAR T-25 Turbo and Bottom mount Manifold, Oil catch can , Fuel pressure Regulator , Oil pan w/welded bung Last edited by lrb99; 11-17-2010 at 08:43 PM.. Reason: parts update |
| Sponsored Links | |
| | #4 |
| Zilvia Member ![]() | I have an emanage ultimate ecu, brand new. Very solid ecu, however not enough for the 1000cc injectors im running. $400 obo From the GReddy site: The GReddy e-manage Ultimate is as close to a stand-alone management system as you can get while maintaining the best features of a "piggy-back" engine management; an economical price, the usage of existing sensors, the ability to easily alter factory settings and not having to tune from scratch. But unlike the original e-manage, the Ultimate is more refined, requiring specific application usage (which we are constantly adding application updates that you can download FREE via greddy.com, Tech WebPages.) The benefit of this is, the included PC-based USB "Ultimate Support Tool" allows for even finer tuning capabilities, improved flexibility in fuel & ignition control and adds impressive data-logging qualities to make tuning quicker and easier. The increased number of input and output ports of the Ultimate, along with new built-in adapters add many new options to the unit. In addition to standard e-manage airflow-based adjustments, the Ultimate version includes new and upgraded features. The Parameter Set-up, tab menu format of the Ultimate has improved direct Map control for adding and subtracting Fuel and Ignition. The ability to switch between 2 preset tuning Maps (i.e. Street or Race program) via externally mounted toggle switches. There are Maps for Individual cylinder adjustment for both Fuel and Ignition. There are also options to convert injection and ignition systems (i.e. group or sequential injection and group or individual fire ignition.) An Airflow Output Map option even allows for airflow meter elimination. And when used with a wideband A/F Meter, the Air Fuel Target Map can self-tune an Injector base tuning Map, to speed up initial tuning. There are also built-in Boost, Rev and Speed Limiter-Cut features. To create super smooth operation, there are various fine tuning Correction Maps to adjust for Throttle Acceleration, Vehicle Speed, Water Temp, Intake Temp, Auto Trans Shift, Anti Engine Stall, and Idle. To further aid in tuning, e-manage Ultimates improved integrated Monitoring, Map Tracing and Datalogging features far exceed any other piggyback controller on the market. Even when not connected to the software, 8 channels of datalogging (at 20msec intervals) can be recorded and stored to be reviewed later. With the Support Tool connected, over 30 channels can be covered. Other new features include: Improved RPM recognition, Warning Settings, Password Protection for individual tuning Maps, NVCS (Nissan), VTEC (Honda), O2 Feed-back, Clean Fouled Plugs, and numerous others in future updates. Ideal for optimizing and fine-tuning for performance products like Exhaust, Air Intake, Intercoolers, Boost Controllers, and Turbochargers, the e-manage Ultimate fills the gaps between conventional piggyback and expensive stand-alone engine managements. All installation and tuning should only be made by a trained technician with proper air/fuel monitoring tools. (Some or all functions may not be compatible with some applications.) |
| | #5 |
| Nissanaholic! ![]() Join Date: Nov 2004 Location: Alberta, Red Derp Age: 32
Trader Rating: (0) Feedback Score: 0 reviews | Not to destroy the dudes sale, but I'd rather run a AEM<motec<viipec just from the tuning aspect. Go to AMS's site and consider getting a full rebuild kit if you want to do it right. Also get overbore pistons and get the machine shop to match your block to the pistons and crank. Get oversized bearings too for the same reason. Do it right, or don't do it at all.
__________________ KA-T ORG-Function over Flush |
| | #7 | |
Trader Rating: (3) Feedback Score: 3 reviews | Quote:
| | #9 |
| Join Date: May 2010 Location: kansas city kansas Age: 22
Trader Rating: (0) Feedback Score: 0 reviews | I'gve got a garret T3 / 04 turbo, efi specialists tune, tuned for 740cc injectors, z32 mafs and the t3. and I've got everything you need except the mafs... if yer interested pm me |
| | #14 |
| Zilvia FREAK! ![]() Join Date: Mar 2004 Location: sa Age: 31
Trader Rating: (23) Feedback Score: 23 reviews | Will get you pics later on today but this is what it will come with. holset h1c jgs manifold oil lines and adaptors nissport oil adaptor oil feed sandwich just in case you need more oil ports 38mm tial wastegate IC setup 550cc dw injesctors efi specialist tuned ecu(z32 maf, 550 injectors and for a t3/t4 setup) z32 maf aftermarket down pipe and 5 bolt o2 housing(just in case you want to change to a more common style t3/t4) rfl bov tapped oil pan also have a brand new aem uego and some extra gauges that I could include also.
__________________ Signature image exceeds allowable size. |
| | #15 |
| Zilvia Addict ![]() Join Date: Feb 2009 Location: Upland CA Age: 24
Trader Rating: (44) Feedback Score: 44 reviews | Hey whats up I got a 2.5" v-band & clamp ![]() turbo intake pipe with welded 5/8 bung (for valve cover breather) and 19mm-3/4 bung for recirc of bov lmk ![]() ![]()
__________________ |
| Sponsored Links | |
| | #18 |
| Post Whore! ![]() Join Date: Jul 2005 Location: (714) OC area
Trader Rating: (129) Feedback Score: 129 reviews | HKS POWER: HKS GT-RS Turbo - HKS Exhaust Manifold - HKS Type S FMIC Core - HKS Intake **NO more S13** - All "vutony" Parts For Sale!! 1.3
__________________ i have engine hoist for rent i do SR wiring |
| | #19 | |
Trader Rating: (44) Feedback Score: 44 reviews | Quote:
i bought it, and never installed. this sets the turbo forward and allows room for the bmc, lmk ![]()
__________________ | |
| | #20 |
| Zilvia Junkie ![]() Join Date: Oct 2005 Location: Farmingdale, New York Age: 27
Trader Rating: (17) Feedback Score: 17 reviews | I got a greddy turbo timer, and greddy profec B spec 2 boost controller, a set of 370cc injectors, greddy turbo elbow for t25/t28 and downpipe. HKS SS BOV, Front mount intercooler (no pipes). Let me know what you're interested in. |
| | #21 |
| Zilvia Addict ![]() Join Date: Nov 2006 Location: Colorado Age: 26
Trader Rating: (5) Feedback Score: 5 reviews | I have a sidemount off of an sr complete, a ebay mani, t25, sr370cc injectors, and an elbo with 1 broken stud make me an offer
__________________ [SIGPIC][/SIGPIC] |
| | #28 |
Trader Rating: (3) Feedback Score: 3 reviews | I just got a t25 turbo and manifokd ,catch can and fuel regulator still need a FMIC and piping I also need a HKS bov and 370 injrectors and other pieces to finish my kit |
| | #30 |
| Zilvia Junkie ![]() | i have a SR greddy/trust downpipe with O2 bung welded on, all u need is to extend it a bit to fit KA-T. $100 + shipping ![]() ![]() ![]() |
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
