| | #1 |
| Leaky Injector | I had my cams out for a while, and now that I'm putting them back in, I realize I have them mixed up! In appearance, they both look the same. How do I tell which is for the intake and which for the exhaust? |
| Sponsored Links | |
| | #8 |
| WOW addicted ![]() | It (among other things) can get worn down, and break off under there. *It also causes some rattling under the chain cover. *There is a lower cahin guide (on the Upper chain) that causes this also, and can be removed. *But its harder to get too. (Edited by sykikchimp at 7<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>3 pm on Mar. 2, 2002) |
| | #9 |
| Leaky Injector | thanks for the info. BTW, what position are the lobes for the first cylinder supposed to be at in TDC? Just wanna make sure I didn't screw up before I slapped everything else back on. |
| | #10 |
| Nissanaholic! ![]() | are there any ill effects of removing the chain guide? Just wondering if it would be more likely to hop off the teeth or something, seeing as how it is the "chain guide". <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> |
| | #11 |
| Leaky Injector | I don't see any problems with removing the upper guide. There really isn't much reason for it to be there. However, the side one is questionable because it may keep the chain from sloshing around inside the upper cover. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
