Old 03-02-2002, 05:11 PM   #1
I have a 1997 240sx and it is stock right now. I wanted to know what mods i can do to my car to make about 200hp without turbocharging. I want to build my motor and get more horsepwer at the same time so in the future i can turbocharge my car. can you list each mod i can do and how much hp it will add? so far i just know about intake, headers, and exhaust.
DM240sx is offline   Reply With Quote
Old 03-02-2002, 05:50 PM   #2
DSC
New Title
If your planning on getting a turbo anytime soon I would just save up for it. *If its a long way down the road, some things you can do now are: Intake, Header, exhaust, lightened flywheel, lightened underdrive pully, port and pollish head (no real hp gains here, but makes things smoother), new cams, ECU, electric clutch fan, umm new spark plugs and wires...umm out of ideas. *Anybody want to add anything else?
Oh, and when you get the turbo you will have to get rid of the exhaust, intake, header, cams (kinda depends on what you get), and you will have to get your ECU reprogramed. *In the long run its really not worth it to do N/A tuneing just to switch over to turbo later because you will have wasted soo much money in the process. *All that above might cost as much as a cheap turbo kit or atleast 2/3's of one and won't give you anywhere near the power or potential. *With the above N/A setup you wouldn't have 200whp, maybe 18xwhp? someone correct me if i'm wrong on that. *I always say this <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> but...if you are planning on a turbo or engine swap just be patient and don't get stuff for N/A tuneing...If you must get soemthing now cauz you can't stand not modding your car then work on brakes, suspension, interior, or sound or something that won't have to be replaced when you finally get the turbo.
(Edited by DSC at 6<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>2 pm on Mar. 2, 2002)
DSC is offline   Reply With Quote
Old 03-02-2002, 08:31 PM   #3
what does an electric clutch do and why would you want to get one?
drifting240racer is offline   Reply With Quote
Old 03-02-2002, 09:47 PM   #4
DSC
New Title
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from drifting240racer on 8:31 pm on Mar. 2, 2002
what does an electric clutch do and why would you want to get one? </td></tr></table><span id='postcolor'>electric clutch fan <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> well your clutch requires (usually) a fan to cool it proerly. *The stock fan it attached to err umm somewhere via belt and it takes power from your engine to spin it. *When it is removed and replaced with a fan powered by electricity, it frees horsepower...not much but with n/a (and any other but especally n/a) tuneing every little bit helps. *The lightened underdrive pully is the same effect.
Old 03-02-2002, 10:03 PM   #5
Will never get banned...
camppain's Avatar
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
im swapping to a sr once everything is right
currently all i did was rims agx struts and prokit springs the 300 brakes will be in my car by this week and thats all except for a few othe rsusp tuning
i agree with dsc do not waste money if your going turbo eventually focus on susp and brakes maybe some cosmetics
camppain is offline   Reply With Quote
Old 03-03-2002, 11:41 AM   #6
HippoSleek's Avatar
Not quite my understanding of a clutch fan, but otherwise DSC is on track. *
I know there are some out there who have completely done the insides and outside of a KA and not hit 200 whp. *It ain't worth the money. *
As for your request, you might try some searches based on these mods and see what people say. *First, you are just being #### lazy (make you a list!). *Second, unless someone has taken the trouble to dyno every step of the way, you won't get a valid answer anyway. &nbsp;Third, study up a bit on the bare BASICS of turbo and NA build ups before you ask a question like this (if you had, you would realize that about 50% of hp enhancements to NA motors are bad/useless for a turbo (e.g., headers, intake, higher comp., ECU, etc.)).
Welcome - now please don't be such a nube <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
(Edited by HippoSleek at 9:46 am on Mar. 3, 2002)
HippoSleek is offline   Reply With Quote
Old 03-03-2002, 12:04 PM   #7
Send a message via AIM to Ni5mo180SX
The KA's can hit 200hp without too much stress. Id figure it would involve mostly head work. Nissan built up a KA24DE that was going to be used in the old Z car prototype and the KA in that concept Z was putting down about 200-210hp all motor. So if Nissan can do it and then use it as a production engine, it must tell you something about the engines reliabilty at that power level and streetability.
Ni5mo180SX is offline   Reply With Quote
Old 03-03-2002, 12:15 PM   #8
ca18guy's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from Ni5mo180SX on 12<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>4 pm on Mar. 3, 2002
The KA's can hit 200hp without too much stress. Id figure it would involve mostly head work. Nissan built up a KA24DE that was going to be used in the old Z car prototype and the KA in that concept Z was putting down about 200-210hp all motor. So if Nissan can do it and then use it as a production engine, it must tell you something about the engines reliabilty at that power level and streetability. </td></tr></table><span id='postcolor'>
Have you ever seen a 200hp KA24DE? Ever hear of someone with one? &nbsp;IIRC the old Z concept &quot;would&quot; have had a 200hp n/a 4 cylinder, the concept had a regular KA cause it was test mule that needed a engine. They never actually made a 200hp ka for the old Z. &nbsp;They would have made one eventually but the feedback for the old concept was horrible.
ca18guy is offline   Reply With Quote
Old 03-03-2002, 12:46 PM   #9
Thanks for the help everyone. I reconsidered about turbocharging my car and I don't think I'm going to anymore. I just want to be able to hang with/smoke most domestics. It doesn't have to be all in particular but just enough to hang. Can you guys help me reach that goal?
derell
Old 03-03-2002, 12:51 PM   #10
ca18guy's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from DM240sx on 12:46 pm on Mar. 3, 2002
Thanks for the help everyone. I reconsidered about turbocharging my car and I don't think I'm going to anymore. I just want to be able to hang with/smoke most domestics. It doesn't have to be all in particular but just enough to hang. Can you guys help me reach that goal? </td></tr></table><span id='postcolor'>
HHHmmm you don't want a turbocharger but want to hang with domestics (when I think domestic I think mustang 5.0) well there is one other choice.
Old 03-03-2002, 12:58 PM   #11
hehe.....true very true. what would you guys do with 2grand in mods excluding tires/rims/stereo? just performance.
derell
Old 03-03-2002, 01:02 PM   #12
what do you think my ¼mile would be and how fast would i do my 0-60.
Old 03-03-2002, 01:18 PM   #13
ca18guy's Avatar
Do you mean your 1/4 mile time with nitrous? If I had to guess it would be about a 14.5 and a 0-60 of about 6 seconds, again those are guesstimations. &nbsp;With your $2000 you could get a exhaust, header, intake for alittle over a $1000. &nbsp;If you pay to have them installed then it will cost you for that header. &nbsp;Then with the extra money maybe get a 40 shot of nitrous and make sure you get it professionally installed if you have any apprehensions about installing it yourself.
Old 03-03-2002, 01:18 PM   #14
Hey, that's my Passport, Aya !
drift freaq's Avatar
Trader Rating: (80)
Send a message via AIM to drift freaq
ok guys, time to dispell more rumors .
first off getting 200hp out of a NA KA is not as hard as some of you think. Its been done many times here in Cali and the motors have been smog legal.
you guys really need to take a look at the socal240sx.org website
look at Alex Changs car. He has JWT ecu and cams a $1000. upgrade and he is pulling close to 20 more hp on a KA24De with just those mods now add intake, exhaust and a few other things and you are going to wind up very close to 200hp.
Rebello racing in Pacheco will build you a 210 hp KA that will pass smog for $3500
Now the thing to remember here is this.
If you are going for that kind of horsepower NA you would bump your compression up to 10:5 with JE pistons $750 . Lighten your flywheel , balance your bottom end port your head ,drop those JWT cams and ecu and for about $2000-$3000 you would find your self right on target at 200 hp NA .
NOw if you are planing Turbo then the only thing you would want to even think about doing was the ecu . JWT does reprograms for their ecu owners for $100 i.e. you buy it now for $500 for more stock performance when you set the turbo up they recurve it for the Turbo.
thats it in a nutshell . proven ways you can go that do work
SEO by vBSEO 3.3.0
