Old 08-19-2012, 01:20 PM   #1
HELP----->>s13 sr20det trans blown or clutch?
my s13 trans gave out, help all gears go in clutch has pressure but the car doesnt move its like if it had no axel i was driving normal pace i felt the car driving a bit sluggish before it gave out and the shifter viberated a bit then it just felt as if the gear poped out but it was still in gear, what could it be trans or clutch or something??
jdmRB2011 is offline   Reply With Quote
Old 08-19-2012, 07:32 PM   #2
leung's Avatar
Trader Rating: (71)
Feedback Score: 71 reviews
can you start the car with it in gear and foot off the clutch? if so clutch is done
leung is offline   Reply With Quote
Old 08-19-2012, 10:59 PM   #3
no its not the clutch its a new spec i only put 460 miles on it
Old 08-19-2012, 11:41 PM   #4
brndck's Avatar
Trader Rating: (95)
Feedback Score: 95 reviews
you didn't answer his question.
if you can put the car in gear with the engine off, but cannot put the car in gear with the engine running, then you either have a bad clutch, problem with the hydraulic system, or possibly a broken pivot ball.
do some investigation, and report back. we can't give you answers unless you give us good information.
I am the future Eric Castro
Old 08-20-2012, 05:03 PM   #5
it goes in all gears but it feels too smooth like if the car is off im pretty sure its the trans because the clutch pedal feels normal and theirs no leaks anywere??
Old 08-20-2012, 06:31 PM   #6
godsmack's Avatar
is the shifter almost free feeling? your shifter might of just came out. take the boot off and crack open the shifter housing and check that out. but yea if the car is on and you can move the shifter around i'm gonna go with that. since usually you'll only blow out a gear and from hard driving.
godsmack is offline   Reply With Quote
Old 08-20-2012, 06:37 PM   #7
ericcastro's Avatar
I bet your clutch bolts backed off the flywheel.
Happened to me. same feeling.
the clutch still has pressure cause its pushing the plate, but its backed off the bolts enough not to engage.
trans prob, wont go in gear when on......
Old 08-20-2012, 06:59 PM   #8
when the car is on i can put it in gear without pushing the clutch down??
Old 08-20-2012, 07:06 PM   #9
godsmack's Avatar
check the shifter like i said. it could've possibly popped out. happened to me already. but if the ball is still in then you need a new trans.
Old 08-21-2012, 05:42 PM   #10
any of you guys ever dropped the trany without have to bring down the whole swap?
Old 08-21-2012, 09:41 PM   #11
brndck's Avatar
Trader Rating: (95)
I'm not sure what you mean by "the whole swap", but I've done more than one 240sx trans swap on just jack stands. Hell, Castro has even done clutch replacements at the track iirc.
Old 08-21-2012, 10:46 PM   #12
ericcastro's Avatar
What do you mean? You dont need to do anything to the engine, it does make it easier if you loosen the engine mounts a bit so the engine can tilt a little when you pull the tranny off.
finishing the 4 hour clutch swap at the track with
nates help
and did it solo at my house over 2 evenings on a LA street.
put the car on jack stands!!! and use the jack to help lower the tranny!!
Old 08-22-2012, 02:50 AM   #13
eddieflo's Avatar
Send a message via AIM to eddieflo Send a message via MSN to eddieflo Send a message via Yahoo to eddieflo Send a message via Skype™ to eddieflo
I'd be sooo scared to put my car up on jack stands like that! Shits gangster as fuck!
Wastelandfresh.tumblr.com & soundcloud.com/eddieflo
eddieflo is offline   Reply With Quote
Old 08-22-2012, 04:05 PM   #14
I dont see how 4 jack stands under the frame is ghetto?
Prozac is offline   Reply With Quote
Old 08-22-2012, 04:31 PM   #15
lol good shit im gona start dropping my pos trans tomorrow
Old 08-22-2012, 04:58 PM   #16
Old 08-23-2012, 05:28 PM   #17
could this be the reason
SEO by vBSEO 3.6.0 PL2
