Old 07-30-2012, 01:40 PM   #1
silviagtir2's Avatar
rb25 ecu
been having trouble with my car. it has a series 2 rb25det with greddy plenum, q45 throttle body, full race exhaust manifold, and garrett turbo. (stock maf and injectors) anyway. it drives fine but smells pig rich and cant run o2 sensor. when i connect it, it fouls out my plugs almost instantly. i was told i may have the wrong ecu... im hoping someone here can identify it. when i type in the numbers its all in russian and all i seem to find is that its from a nissan laurel. thanks in advance!!
silviagtir2 is offline   Reply With Quote
Old 07-30-2012, 03:06 PM   #2
SR/RB Guru
Sileighty_85's Avatar
Weird, FAST system doesnt recognize this Part Number
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Sileighty_85 is online now   Reply With Quote
Old 07-30-2012, 03:23 PM   #3
Yea it's weird, I found something that said it's for an RB25DE, but it's in another language.
Old 07-31-2012, 01:05 AM   #4
R.I.P. David Mudge
zerodameaon's Avatar
I believe that's a Euro C34 RB25DE ECU or some mash up that's not often seen, when I ran the numbers the first time it came up with CA16DE.
Your looking for this guy here.
R33 GTS25t RB25DET Series 2 Manual RWD 23710 13U01 MEC-R721 A1 7207 (#G8)
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is online now   Reply With Quote
Old 07-31-2012, 10:49 AM   #5
Thanks for the info. I found a mines tuned ecu with those numbers, would you recommend a mines ecu?
Old 07-31-2012, 04:59 PM   #6
R.I.P. David Mudge
They aren't bad. How much is it going for is the real deal breaker.
Old 07-31-2012, 09:15 PM   #7
I'm getting it for 200. But the thing is I don't know what mines ecu's are tuned for
Old 07-31-2012, 09:17 PM   #8
SR/RB Guru
Then dont buy it unless you know for certain.
For all you know it could be a GT35R with 1000cc injectors and a Z32 MAFS
後輪駆動車1番
1986 SR86 - 200ish
Old 08-01-2012, 04:22 PM   #9
R.I.P. David Mudge
Agreed, unless you can get it retuned or guarantee its for stock then shy away and stick with stock.
Old 08-03-2012, 10:21 AM   #10
ok. so i ordered the mines ecu anyway and decided to give it a try, and if it didnt work return it! tried just direct ecu swap.....nothing! Then thought it might be tuned for z32 maf, so tried that....still nothing! but it will fire up with no maf connected at all, just wont rev past 3k. Is there any other maf possibilities they might have used to tune that mines xprom??
this is my current setup
Old 08-03-2012, 11:11 AM   #11
SR/RB Guru
What color is the tag on the MAFS and the # .
Your should be a Pink Tagged E60 for a Series 2
Certain Years Infinity J30 chassis should have the same MAFS
後輪駆動車1番
1986 SR86 - 200ish
Old 08-03-2012, 11:37 AM   #12
rb25 s2 maf i have is an e60 pink label
z32 maf is n62 orange label.
i know both mafs are good.
Old 08-03-2012, 11:47 AM   #13
PrimeDirective's Avatar
I think your asking for trouble with using that mines ecu at all. No one really has any idea on what its tuned for. You are going to have problems, for example, a lot of those tuner ecus from Japan are tuned for 98-100 octane gas. Also who knows what injectors that thing is programmed for either. Just get a stock ecu to get your self on the road. You could of been driving this thing already!
Also, fyi, your catch can/pcv system is fucked, you are going to suck in un-metered air when the pcv valve is open and the valve covers will never see vacuum. If you are going to use that system get rid of the filter vent and connect it to the intake between the turbo and the maf.
PrimeDirective is offline   Reply With Quote
Old 08-03-2012, 11:58 AM   #14
Ok. Thanks for the info bro
Old 08-03-2012, 12:20 PM   #15
Trader Rating: (32)
Feedback Score: 32 reviews
Like the others have said, who knows what its tuned for. Return it while you can. Save a lil more and atleast get powerfc or 300zx ecu with nistune. Then you can input proper injector size and maf. Not to mention get a tune that matches the airflow requirements of your setup. That intake kills velocity which means low end torque, so does that throttle body. Thats probably why so rich down low. Then once that turbo spools you wont have enough fuel to even use it much above 7 psi. And the timing will be off too.
Bottom line get a proper ecu/tune, dont bandaid over something like brain surgery.
futurefabrication.com
FutureFab is offline   Reply With Quote
Old 08-03-2012, 01:16 PM   #16
Thanks guys, I appreciate the help. Just got outta the post office and returned the ecu. Question though, what ecu is required to run nistune? I've heard z32 but a local shop tells me I need an r32 gtr ecu...any suggestions???
Old 08-03-2012, 01:37 PM   #17
Trader Rating: (32)
Gtr ecu doesnt have vct capability. 300zx does.
Old 08-03-2012, 11:23 PM   #18
R.I.P. David Mudge
Straight from Nistune, this should answer your questions. Nistune is a great way to jump up to standalone status and not break the bank. Stay away from the GTR ECU unless you plan to take off the VCT or move that head over to a RB30 setup.
http://nistune.com/docs/Z32_ECU_Modi...lugin%20V8.pdf
Old 08-04-2012, 12:14 PM   #19
thank you guys so much for your help. hopefully i can get this thing to finally run right.. anyone happen to have a z32 ecu for sale? lol
Old 08-11-2012, 03:44 PM   #20
R.I.P. David Mudge
This should work for you, scroll down a bit.
Circuit Sports, Megan Racing, 180SX garnish, SR, CA, Z32, etc SALE!!!
SEO by vBSEO 3.6.0 PL2
