Old 07-23-2012, 12:18 PM   #1
SR sr wont turn over
Hey I have my Sr in and all wired up but when I turn the key i just makes this clicking noise I found out the noise is coming from this relay on the drivers side it says acc on it can anyone help me out with this problem really want to get this car done
1992s13hatch is offline   Reply With Quote
Old 07-23-2012, 01:54 PM   #2
Dorifto Machine's Avatar
Is it getting fuel, is your fuel pump priming ?
Dorifto Machine is offline   Reply With Quote
Old 07-23-2012, 02:13 PM   #3
steve shadows's Avatar
Get a hammer - a rubber mallet is better and hit it against the side of the starter several times 3-5 times then try to start the car again. If the battery is in good shape then the starter gear is probably jammed against the flywheel happens every once in a while with older starters that aren't in perfect shape. The knocking against the body of the starter with the rubber mallet should dislodge the gear and you should be able to start it right up.
Otherwise it's these other two possibilities:
-The starter itself is starting to die
-The battery is dead or doesn't have enough cranking amps
Hope this helps.
Like Us on FaceBook !
http://shadowerks.com Remote Tuning and Base Map Services
Old 07-23-2012, 02:45 PM   #4
I don't hear the fuel pump kicking on or priming when I try to start it it just makes a sound like there's a dead battery
Old 07-23-2012, 09:40 PM   #5
Ok I got it to where the starter is spinning but not ingauging ill try the mallet tomorrow but does anyone have a clue why the fuel pumps not sounding like its kicking on
Old 07-23-2012, 09:55 PM   #6
Cease_Super_Hicas's Avatar
Trader Rating: (30)
Feedback Score: 30 reviews
Send a message via Yahoo to Cease_Super_Hicas
Check ur fuel pump fuse
http://i643.photobucket.com/albums/uu153/RB20DETHKS/b022769b-1-1.jpg
Cease_Super_Hicas is offline   Reply With Quote
Old 07-23-2012, 09:57 PM   #7
I did it was ok its a 10 amp fuse right
Old 07-23-2012, 11:14 PM   #8
Hoffman5982's Avatar
Then your wiring is probably wrong
Old 07-23-2012, 11:25 PM   #9
All the connectors are connected though
SEO by vBSEO 3.6.0 PL2
