Old 07-16-2012, 09:47 PM   #1
Wearing What You Drive
dorkidori_s13's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
Send a message via AIM to dorkidori_s13
02 sensor issues w/S13 SR Blacktop (yes ive searched, been doing it for over a week)
hi all
before i start, i dont want some bullshit answer like "oh just get rid of your 02, its fine without it". the point of this thread is that i NEED a fully functional 02 sensor!
with that being said...
i got my hands on a consult port cable with USB link. im running ECU Talk 1.3.5 software to monitor my ECU/Sensors via the consult port. now the problem im running into is that i dont think i have the correct 02 sensor, OR, something is really messed up.
i JUST replaced my 02 sensor on my S13 BLACKTOP SR20DET (NOT S14/S15 NOTCHTOP!!!) about 3 weeks back with the USDM fat type BOSCH from a 95 300zx TT (part#13091). i am currently trying to pass a sniffer and my CO levels arent stirring the Kool-Aid.
upon running ECU Talk with my consult port setup, the software gauge for the 02 sensor is showing me NOTHING. the gauge is capable of reading between 0 and 1 (volts). the 02 sensor SHOULD be working even when the motors cold and warming up (hence, its a heated 02 sensor). well, again, ECU Talk is showing me nothing for my 02 sensor. my A/F ratio gauge is stuck in the center at 100 (it twitches sometimes but immediately moves back to 100). i multimetered the 02 plug on the SR harness, i am getting power and such from it.
so yeah, im REALLY stuck. i have exactly a week to get my car "smogged" (as long as i can pass a sniffer im fine), but until my 02 sensor starts working, my SR is running like shit and wont pass the sniffer test because of CO levels that are way off after the high speed test.
YES, DORKIDORI IS MAKING NEW SHIRTS! CLICK THE BANNER!
ADD DORKIDORI ON FACEBOOK! CLICK HERE!
Bought something from me??? POST A REVIEW HERE!!!
Old 07-16-2012, 10:33 PM   #2
Wanabe's Avatar
Maybe you got a bad O2 sensor? Probably not but just a thought.
Wanabe is offline   Reply With Quote
Old 07-17-2012, 12:31 AM   #3
jholman's Avatar
try an O2 off of like a 93 Sentra Se-R. It may work?
jholman is offline   Reply With Quote
Old 07-17-2012, 12:37 AM   #4
Trader Rating: (37)
FWD SR20de 02 sensors are incompatable with RWD SR20det motors (from everything ive read, which literally feels like EVERYTHING but the answer i need)
and it has already been determined time and time again that the SR20det S13 redtop and S13 blacktop 02 sensors are completely different in their operation based on 02 sensor make up and ECU functionality.
not bitching you out or anything, just stating it so it doesnt get repeated in the thread (should the thread actually continue)
im halfway tempted to try a redtop 02 sensor just for shits and giggles (since its one of the FEW things i havent tired)
Old 07-17-2012, 01:33 AM   #5
cotbu's Avatar
Is the ecu chipped? Maybe 02 sensing is turned off.
If not check the voltage at the sensor harness.
Old 07-17-2012, 02:11 AM   #6
do you get ANY voltage readings. and are you letting the car FULLLY warm up to operating temp ,mine settle at around 70*C, before trying to get readings? also, what brand of windeband are you using? my AFR's were REALLY low, like sub 10's, before i had my timing adjusted. if could be something there. also was it working before you changed your o2 sensor?
riptor is offline   Reply With Quote
Old 07-17-2012, 09:03 AM   #7
Trader Rating: (37)
as far as i know, the ECU is oem (i havent cracked it open to look yet).
im not using a wideband riptor. i didnt check my last 02 sensor before i pulled it (dumb ass me), this was before i had my consult cable and software.
Old 07-17-2012, 09:21 AM   #8
JDMRIDDAZ's Avatar
ok on sr20det swaps theres a brown wire from sr20det harness...connecting at the f9 f10 connectors by where battery is located
that needs ignition...this gives power to o2 ...
if ur not getting any readings
also if o2 sensor wires were extended were they extended with the correct wire...
also ur car should run fine w or w out o2 plugged in...and ive used both on a blktop and redtop visa versa...no real diff..
go over all switch wires at those two plugs make sure they are getting 12v and above when car is running if voltage is crappy on any of these wires ur swap will not run correctly
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
Old 07-17-2012, 10:14 AM   #9
lol...i mean what was the reason for changing your o2 in the first place.
Old 07-17-2012, 01:17 PM   #10
Trader Rating: (37)
sniffer as in smog
the CO levels are going thru the roof for a few seconds once i let off the throttle after the high speed RPM test. its causing me to fail the sniffer test for smog inspection (and yes, my BOV is recirculated). the car has never run 100% thru the initial power band where the 02 sensor matters the most. im guessing the 02 sensor has never worked to begin with.
Old 07-17-2012, 01:23 PM   #11
Trader Rating: (37)
forgot to mention, i got a multimetere out yesterday and tested the plug. it IS receiving voltage. im just not getting a reading from the 02 at all.
Old 07-17-2012, 08:10 PM   #12
cotbu's Avatar
Did you crack open that ecu? I think sensing is turned off, and probably knock too!
Old 07-17-2012, 08:16 PM   #13
Trader Rating: (37)
havent opened the ECU. outside of chipping it, how the hell would you turn that off?
Old 07-17-2012, 08:33 PM   #14
What ecu are you running in the car? Is it a redtop #62 or blacktop e5? The blacktop e5 ecu grounds the o2 sensor thru the ecu itself but the redtop #62 ecu grounds the o2 to a chassie ground. I had the same issue i was using a #62 ecu on a blacktop motor in my s13 and got the correct skinny o2 but it was unresponsive. After grounding to valve cover for the fun of it the o2 started working. Hope this helps.
mobmotorsports2002 is offline   Reply With Quote
Old 07-17-2012, 08:34 PM   #15
cotbu's Avatar
unplug it!
If the 02 sensor is working and wiring is correct, you would get a reading from the consult stream, period unless you say don't monitor this stream.
even if you used , the narrow band output from a wideband, redtop or blacktop 02, or a generic 3 wire whatever. as long as they are wired correctly you should see something. working correctly is a different story.
You verified continuity from the signal wire from 02 to the ecu correct. If you are not chipped I'm lost if you checked the wiring.
Old 07-17-2012, 08:37 PM   #16
Trader Rating: (37)
i have an E5/E6 ECU
so by unplugging it, the ECU will reset?
Old 07-17-2012, 08:45 PM   #17
cotbu's Avatar
No, the ecu will just run what the map tells it too! You might be close to stoich or far from either direction, but no correction from the 02 sensor, all mapping!
Also no new learning, you could clear the long and short term trims and I know most of the time the ecu will run lean for a short period. not really hear nor there!
Old 07-17-2012, 08:54 PM   #18
AEM's UEGO O2 Sensor Test - How to check to see if your aftermarket O2 sensor is bad - YouTube
blessedhellrider is offline   Reply With Quote
Old 03-20-2013, 10:07 PM   #19
Does your sr kinda hickup when you drive it and seems way underpowred.
xMOAR LOW S13x is offline   Reply With Quote
Old 03-21-2013, 10:43 AM   #20
ultimateirving's Avatar
Listen man, i haev same ecu and had issues with my o2 sensor not working. Sooo i cut the signal wire that tells the ecu how much voltage the o2 unit sees, i wired that directly to the o2 input on the ECU.
I ran my own wire and from then on i was able to see the o2 voltage in consult..
Sr20det-e85 - 2871r - Ksport coilovers.
SEO by vBSEO 3.6.0 PL2
