| | #1 |
| Leaky Injector ![]() Join Date: Jan 2012 Location: Minnesota Age: 19
Trader Rating: (0) Feedback Score: 0 reviews | WHAT is this noise!?! sr20det so, ive got a video of this noise, after my car hits a certain rpms.. it just started happening yesterday and i dont have a clue on what it could be.. any help or if anyones had a similar problem, any advice would be appreciated. thanks guys http://s209.photobucket.com/albums/b...t=IMG_6797.mp4 i dont know how to upload straight to here.. :S |
| Sponsored Links | |
| | #2 |
| Zilvia Junkie ![]() Join Date: Feb 2009 Location: Allentown, PA Age: 27
Trader Rating: (0) Feedback Score: 0 reviews | not sure exactly what it is but sure doesn't sound good. i wouldn't do that too often until you find the source of that noise. i would pull the valve cover and look at your head and check all the rocker arms. |
| | #3 |
| SR/RB Guru ![]() Join Date: Dec 2006 Location: Misawa, Japan
Trader Rating: (5) Feedback Score: 5 reviews | lol sounds like a spun rod bearing
__________________ 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
| | #4 |
Trader Rating: (0) Feedback Score: 0 reviews | yeah, i took the valve cover off and looked, the only source of something going wrong is two rocker arms/cam lobes that appear to look scorched cuz of being so hot? do you think that would make the noise?.. but what would cause just two of the rockers to be like that? |
| | #6 |
Trader Rating: (5) Feedback Score: 5 reviews | scoring is probably from lack of oil from a bad oil pump
| | #8 |
Trader Rating: (5) Feedback Score: 5 reviews | youtube spun rod bearings for Sr's and see if it matches your sound. Usually with SRB they are barely audioable at idle, when reved knocking get louder and faster in the higher RPMs
| | #9 |
Trader Rating: (0) Feedback Score: 0 reviews | i've youtubed a few videos of spun bearings already, i think there was maybe one car that sounded close to mine.. but even that car had a noticeable ''knocking'' which i dont think my car has.. unless i just got really lucky and im catching it before it even really starts to knock? |
| | #10 |
| Leaky Injector | Sounds likes it not running on all 4 cylinders , more like 3 or something , video wasnt the greatest , like android shit or something J.king. Edit: Is it stock, upgrades , ran fine before what? , just put it in? Also create a youtube.com acount and upload then paste a link here to possibly get some better vids. |
| | #11 |
Trader Rating: (0) Feedback Score: 0 reviews | the motor is stock, i just finished the swap maybe a few weeks ago, been working on getting the finishing bugs out of it.. and putting it all back together, ive literally drove the car for maybe a few hours at max of driving.. and it started making this sound one day when i was checking over the car before leaving work.. it ran fine for a day or two before i caught this. it does need some tune up things, which i was getting to this week before this noise appeared. its my shitty iphone quality ![]() http://youtu.be/sEnG-fRhQOU |
| | #14 |
| Leaky Injector | Man this could be as simple as spark plugs , dont know cause of history to pin point one thing, also if you havent already pull some codes to start the process of elimination. Second , I would do a compression test (which you might have done before you ran it ) and see what you get now. And in the process throw some new spark plugs in it if you havent already. Edit: Im packing Iphone 3gs and you will get alot better quality with youtube. Is a video of the storm / rusthole / ecu enema , that took out my ecu. Ky storms - YouTube |
| | #15 |
| Zilvia Junkie ![]() | Use a wooden dowel aka a stick and put it on the motor in different spots and listen at the other end right against your ear. You will be able to pin point top end bottom end and cylinder area with ease.
__________________ Toyota Celica GT-Four R33 GTS25-T M-sport |
| Sponsored Links | |
| | #16 |
| Leaky Injector | Yeah after watching you youtube video , the ticking is just the injectors , the other sound could be a waterpump bearing going out , still working but on the verge of taking a shit, Also what have you done to the engine besides dropping it in? Edit: A Stethoscope is fairly cheap and very uselfull , or wood dowel / Screwdriver metal end to engine plastic to ear to pin-point what area the sound is. |
| | #17 |
Trader Rating: (0) Feedback Score: 0 reviews | i havent done anything to the motor, besides the drop in, its bone stock.. only upgrades are 3" dp, walbro 255, and 3'' exhaust.. motorwise its stock.. but the waterpump is brand new, has maybe 10 miles on it, so i doubt that would be the issue? and i have tried the screwdriver/dowel trick, but i still cant pin point exactly where its coming from.. :S oh and im going to get some new plugs, asap. but the compression read good numbers across the board, i did one of those the first day i got it up and firing. appreciate all the help guys. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
