Old 07-11-2012, 09:34 AM   #1
High rev on start and idle. Finished T build
Just finished turboing my ka24de. When i crank the motor it revs to 3k for 4 seconds then idles at 2k. What can the problem be
S13alldayyo is offline   Reply With Quote
Old 07-24-2012, 12:11 AM   #2
ever fix the probablem? when i can get my car to start it does this... trying to figure it out now... i adjusted the throttle cable and that didnt help. neither did adjusting the IACV
sleepyeyeds14 is offline   Reply With Quote
Old 07-24-2012, 12:33 AM   #3
check for vacuum leaks.
also check to make sure your TPS is properly adjusted
MrSanchez925 is offline   Reply With Quote
Old 08-03-2012, 08:45 AM   #4
it was due to an oil leak problem fixed
Old 08-04-2012, 12:56 AM   #5
wait wat? oil leaks can fix idle issues? maybe cause of crank pressure?
Bentleyness is offline   Reply With Quote
Old 08-04-2012, 01:36 AM   #6
Yep, my car started running bad because I had a cam seal and oil pan leak.
JDM-JUNKY is offline   Reply With Quote
Old 08-04-2012, 01:42 AM   #7
huh i do have a slight oil pan leak and getting -10 vac instead of -20, ill have to see if this fixes my issue
SEO by vBSEO 3.6.0 PL2
