| | #1 |
| Zilvia Member ![]() Join Date: Oct 2005 Location: Parrottsville, TN.
Trader Rating: (13) Feedback Score: 13 reviews | So today as I was driving home on the interstate I noticed that my autometer oil pressure gauge started to move around from about 50psi to 20psi and lower. My first though was that im low on oil. I then checked my oil level and saw that it was good maybe just a little low so I added some oil to my engine and went for a drive. The gauge was reading normal but then after about 20mins it started to bounce around again. My guess right now is a bad oil pump? My motor is a KA with a t28 turbo. Anyone ever experience this problem? Any and all help would be greatly appreciated as this is my daily driver ![]()
__________________ |
| Sponsored Links | |
| | #2 |
| SR/RB Guru ![]() Join Date: Dec 2006 Location: Misawa, Japan
Trader Rating: (5) Feedback Score: 5 reviews | if you not leaking oil then my best guess would be the oil pump is going bad. better replace it before its too late
__________________ 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
| | #4 |
| Leaky Injector Join Date: Feb 2009 Location: Savannah GA/SC Age: 23
Trader Rating: (1) Feedback Score: 1 reviews | I would trouble shoot a bit before I decided to crack into the engine and replace the oilpump. Check the following. Gauge Sender Oil lines/fittings Look for any oil leaks. Does this problem start once you get in boost? A while back I had an oil line that would only leak at WOT.
| | #5 |
Trader Rating: (13) Feedback Score: 13 reviews | I know I need to replace my rear main seal but its not leaking that bad and my oil level is normal. As for the sender how did you know it was bad? Did you have the autometer gauge? Where did you get a replacement from? Thanks ![]()
| | #6 |
| Premium Member ![]() | If you have the sender mounted directly to the engine it is most likely on it's way out, they are known to go out due to the vibration. AMS, prosport and other companies make a 'remote mount' kit for senders that help the life of these somewhat fragile senders. Examples: AMS Remote Oil Pressure Sending Unit Line Prosport Remote Oil Pressure Sender Installation Kit Import Image Racing Homemade: DIY $10 Remote oil pressure sender kit (installed pictures) - NASIOC Best of luck! I had three prosport senders go out before I got the remote kit. |
| | #7 | |
Trader Rating: (13) Feedback Score: 13 reviews | Quote:
__________________ | |
| | #8 |
Trader Rating: (1) Feedback Score: 1 reviews | Did you use teflon tape on the sender? If so, check to see if the sending unit has good ground. Use a volt meter and touch the body of the sending unit to a good ground. If you have 1 volt or more, the unit has a bad ground. The other way to test it would be to check the ohms. 230 ohms at 0 psi, and 270 ohms at 100 psi.
| | #9 | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
